L.E.D. Freak
Heres a pic of the Blue Dot inserts I'm making for Ty. They are something different. I like them. They feature a cluster of 6 Blue LEDs on a board with 162 Red LEDs. THe blue LEDs can be shut off with toggle switch. And change brightness with the parking/ and brake/turn same as red LEDs.
Comments?
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
Old member
NOW I like that! It's awsome.
Are those clear lens? When you make a set of the boards does it include lens are they just the boards. The reason I'm asking when I get ready for them all I need wil be the board I already have the clear lens.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
One word...AWESOME!!!
'71 Chevy C-10 - Current '62 Imapla SS - Traded for my current '73 Nova Hatch - traded for ATC-350X '73 Chevelle Deluxe - First car (R.I.P) DEERFIELD, MA |
L.E.D. Freak
I've been wanting to make these for awhile, so when Ty wanted a set I finally put the time aside to make a set.
Andy. We only sell LED inserts. These are hand made. And as with all hand made custom work, price, time etc... are on a case by case basis. I like the idea of being able to shut off the Blue LEDs when the "Heat" is behind you! LOL
Old member
Yes, me too. I really like the blue dots in the lights, could you pm me with a price for the set and and for just a normal set. Thanks.
P.S. I took my 1/24 suburban and had it dipped today to get all the paint off. Going to try and work on getting it primered this weekend. Got the wheels looking right... Height wise that is. Hope to have some pictures of it sometime this weekend after I primer it.
L.E.D. Freak
Well the standard production inserts you get from our web site. The custom blue dots I can make for $120.00
1969 Custom 30 wrecker
Check with your states laws on blue dots first! Here in Pa, they are illegal. ( extremely stupid but never the less, illegal)
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
L.E.D. Freak
Blue dots are illegal. That is exactly why I'm setting the blue LEDs up with a toggle switch to turn them off when cops are around. No problem. They'll always find a reason to harass and provoke.
Hot Rods For Life
Yer Da Man.
L.E.D. Freak
Thanks for all your good words.
I just want everyone here to know that we do this because we love it. I put alot of time into coming up with new ideas, and making products better. I really love 67-72s. And to all you 67-72 guys feel very special, because these LEDs and the number of LEDs we use is unmatched. You'll be hard pressed to find any LED insert, custom or universal applications that come close to ours. Most are under 50 LEDs per side.
#11 | |
Where's my beer?
Those look great, it's awesome what you've done with those lights, Keep up the good work, I know you'll hook me up later on when my truck gets driveable.
Paul How do you make the invisible, visible?.........You take it away. |
Dreams are free
with this design, Its hard to tell in the pic, But does this give the PURPLE effect in a distance?
'68 swb fleetside originally w.i.p '68 member since 1-01 w.i.p = ( work in progress ) |
#13 |
You make any LED's for Burbs?
Dave aka "Wild" Current truck "Ida Mae" 71 K5 Blazer Former Trucks "Loretta" 71 Longbed (AZ) "Tanya" 69 Stepside (AZ) "Ferdinand" 71 Longhorn (SD) "Patches" 67 Panel (IA/ KY) "Rosita" 68 C30 (KY) Instagram @Wildforwheels @k5_klub @c10university Profile pic provided by Jeff Sundance |
#14 |
Flake Daddy
1968 SWB Fleet Daily Driver 350/TH400 shaved driprail,emblems,tailgate,air ride suspension 1964 Pontiac Catalina 2dr. hardtop shaved everything, air ride suspension 1998 Range Rover 1960 El Camino....in the works..... |
#15 |
Thanks Reumster for making those for me. Man I couldn't have asked for a cooler looking set of LEDs. I love that set up. I can’t wait to see them in my Blazer
Breakin’ the law, breakin’ the law.
This is only my opinion and it is subject to change. 70 GMC Short box stepside Blown 388 Stroker 72 K/5 Blazer 350/SM465/205 |
#16 |
L.E.D. Freak
Thanks again guys!
wild4wheels If your Panel lenses are the same as Sub lenses then yes. The standard fleet side 67-72 insert will fit your Sub/Panel. If you look close at the lenses of a Sub, and the lenses of a truck you can see the Subs are just Truck lenses with extra plastic to make up for the curve on the back of the Sub. All you need to do is use a peice of soft foam behind the insert to keep the insert against the inside face of lense, and make up for that extra space. still w.i.p '68 These blue dot LED inserts look blue with clear lenses(clear used in pic) With red lenses they block alot of the light put off by the blue LEDs but they have a purple tint to them. As far as from a distance I'm not sure. I haven't finished both inserts. And I'm waiting on a title for my blazer to drive it. But I plan on having some one drive my blazer at night and ride behind it to see. With both clear and red lenses. To get a real perspective.
#17 |
Love those Lights!!! they just keep getting better all the time .........thanks for all your hard work
-1972 K20 longbed -350 4 Barrel -4 speed |
#18 |
14.1 @ 96MPH
Those are just nuts...awesome!
Project1970 - LS1 Swap Complete! ![]() |
#19 |
Ryan,
I wish you wouldn't have posted this. Now i have to get a set!! LOL. Those rule!! Tom |
#20 |
L.E.D. Freak
Tom as soon as I get my order of LEDs I'll start a set for you.
Thanks again everyone.
#21 |
sweet
#22 |
Too many projects
Very cool
Jim ![]() ![]() '55 Chevrolet Pickup '56 Chevrolet Belair '04 Chevrolet Astro '95 Chevrolet Blazer |
#23 |
Hey, Reumster, Do you have a picture of what those look like with the blue turned off. I know it will be all read, but I was wondering how much of a gap would be there with out light right there. If only I had money.
Low68
Build Thread |
#24 |
L.E.D. Freak
I'll get some pictures with the blue dot off.
#25 |
L.E.D. Freak
TTT
Here it is SCOTI
