Old 02-11-2010, 04:34 PM   #1
yote1234
yote1234's Avatar
questions about the elimination of EEC canister in 72
i want to eliminate the eec canister in my 72 cheyenne during my restoration. i know the fuel cap needs to be changed to a vented one.
my questions are...
1- can i use my original tank,and neck?
2- do i need new single tube sending unit ?
3- do i run only (1) fuel line from tank to carb ? and what size ?
4- will the new vented cap fit my factory 1972 tank?
5-after change,can i eliminate the in cab wall vent line?
thanx in advance... dave
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 02-11-2010, 06:53 PM   #2
bgons
Re: questions about the elimination of EEC canister in 72
I have the same question
bgons is offline   Reply With Quote
Old 02-14-2010, 12:39 AM   #3
yote1234
yote1234's Avatar
anyone know???
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 02-14-2010, 01:18 AM   #4
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Talking Re: questions about the elimination of EEC canister in 72
1. Yes you can use your original tank.
2. No you do not need a single tube sending unit.
3. Yes only 1 line and either 5/16 or 3/8 line depending on what engine you have you can use your line that is feeding your fuel pump now, unless it is rusted and has holes in it.
4. I am using my orginal cap and I have had no issues, because it is a vented system already, that is what the extra line is going up into the cab.
5. You can but why worry about it? You can't see it and mine never smells the cab up, so I don't really see the need to pull it out.
Hope this helps!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 02-14-2010, 01:30 AM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I couldn't have said it better myself B&B.
When I was redoing my fuel system in my 1972 I even took out all the Evap lines that ran along the frame rails, and blocked them off at the tank. Still have the original filler neck, have a stock unvented cap, and left the stuff in the cab and door jamb alone. No sweat...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-14-2010, 09:04 PM   #6
yote1234
yote1234's Avatar
interesting.so what needs to be done with the extra line on the sending unit? block off? . i thank you for reply's... dave
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 02-15-2010, 07:12 PM   #7
Firefighter
Mine is still hooked up in the cab but it is blocked off by the fuel pump.
Yellville, Ar. USA
Old 02-16-2010, 11:21 AM   #8
yote1234
yote1234's Avatar
thanx..........
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 02-16-2010, 11:38 AM   #9
Firefighter
Anytime!!
Yellville, Ar. USA
Old 02-16-2010, 03:30 PM   #10
GREASEMONKEY72
GREASEMONKEY72's Avatar
i agree, i yanked the canister out of my truck and ive still got the stock vent line and stock cap
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
