Battery relocation?
Has anyone moved their battery from the engine compartment to somewhere else? The passenger compartment, the bed, or underneath somewhere? Just looking for ideas...
Re: Battery relocation?
I plan on relocating to the frame. I purchased a battery tray from CCP. I haven't installed it yet.
Put mine under the bed on the frame behind the passenger side. Made my own tray.
Did you use a regular battery or a sealed one? Do you have any pictures of your install?
![]() Join Date: Oct 2009
Mounted a box for mine right beside fuel cell. I will have hinged access panel in bed floor. CPP (and I'm sure some other venders) have a nice "drop out" box that you can mount on frame and it drops down for access. Good luck..
I didn't move mine but I have another one in the cab right now. Mine sits between my seats for now. Once I get the gas tank moved I will have one in each corner of the rear of the cab.
I moved mine to the bed (back passenger side). I also have a battery cut off switch on the bumper to keep it NHRA legal
I got a drop down battery box from CPP installed it on the passenger side frame under the bed behind the cab. Cables are not much longer than stock. It is easy to access and if you have to change the battery it drops completely down.
1972 Blazer body...need to get a thread started for the rest of the story |
I like the battery drop down tray. That's the way to go. Just cheaper for me to make my own.
That drop out box is pretty slick. I think that's what I'll do.
Thanks! |
I regret not moving mine when we redid my truck, does anyone have a pict of that drop box every is talking about?
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Longtime Member
Rokcrln - "I'm a major car addict so trying to go as low buck as possible is like asking a coke head to use flower to save money." 1972 C10 Short Step -http://67-72chevytrucks.com/vboard/s...d.php?t=261405 |
#13 |
Nova70, don't want to butt in, but I hope you at least mount those in sealed boxes WITH vent hoses going out. Due to the explosive nature of batteries i would not put them in the cab with me. Just my 2 cents worth...
