1964 C-10 Engine
A couple of question's! 1964 C-10 6cyl 3 speed
When changing out 3 speed manual to automatic 400 what do you have to do for cross member mount's? Will I have to do anything for the cooling system, really do not want to use electric fan's, want to keep it stock look. Thank's in advance Last edited by chevelle518; 02-11-2010 at 06:21 PM. |
Doin' it live!
Re: 1964 C-10 Engine
You need a new automatic cross member out of something up to 1974. You will need to add a transcooler but the cooling system for the engine should go unchanged. Just did a th350 auto in my 64. Again, just get the xmember and you should be good.
-Panelrodder 1953 GMC Panel truck - 'Curly' 1961 Chevy Suburban - 'Larry' - Sold 2005 Harley Sportster - 'Shemp' |
#3 | |
You stated anything 74 back , is that truck only or car as well? Thanks Randy |
Doin' it live!
Truck only. Though you should prolly shoot for 67-74. After 74 they changed the design to an 'L' shaped xmember to accommodate the cats put on the newer trucks. They still work, in fact that is what I have, but they aren't quite as nice as the "double hump" xmembers. You can also get an aftermarket one from a couple different manufactures. But with shipping and the purchase price it was way more than the 25 bucks I paid for mine.
#5 | |
Again Thank's |
Doin' it live!
For sure. I've gotten a ton of info from the forum. Figure I'll throw a little back into the pool!
Good luck
With an inline, you should look for a Turbo 350.
1982 K10 SWB 1987 V20 - Sold - Doh! |
![]() Join Date: Sep 2006
Or you could just buy a new one. http://www.truckandcarshop.com/trucks60_72/t60_097.html $69... Try the bone yard first. I got one out of a 65 or 67 I think and it was rivited in. Good thing for battery powered drills.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 02-12-2010 at 11:23 AM. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I agree......there's no reason to run a TH400 behing a stock 6 cyl. The TH400 takes more hp to turn, plus it has a higher 1st gear ratio than a TH350.
