Old 02-11-2010, 09:37 PM   #1
tonypaul
tonypaul's Avatar
1980 factory cross member swap to 1968 GMC
Im swapping a 1980 heavy half (5/8 ton) front cross member into my 1968 GMC swb to get rid of the drum set up. I would like to replace every bushing that I can in the front end before I install it. Can someone give me a suggestion on which kit to go with. I perfer to get everything in one kit....
Thanks in advance!
tonypaul is offline   Reply With Quote
Old 02-12-2010, 12:20 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 1980 factory cross member swap to 1968 GMC
I would check with the board vendors.
I assume you mean a-arm bushings, balljoints, tie-rod ends, idler arm, pitman arm, etc?
Old 02-12-2010, 12:21 AM   #3
lolife99
lolife99's Avatar
Vendor list,...
http://67-72chevytrucks.com/vboard/showgroups.php
