Old 02-11-2010, 11:51 PM   #1
69sixpackbee
Huge Lot EFI System With DynamicEFI "EBL Flash" 7.4 TBI LC-1 WBo2
Over the past several years I have amassed one very large plethora of GM TBI components for a future conversion project that is ultimately never going to come to fruition so my hoard will be someone elses gain!
This was going to be destined to reside on my 402 big block in my 1972 Chevy C-20 peecup but because of the loss of long term employment and other necessary needs over wants I have decided (reluctantly) to liquidate it ALL.
Here is the complete list of ALL of the components I have left.
* 1- Modified GM #1227747 ECU with DynamicEFI's "EBL Flash" including the WUD software and RS485 comm. cable. <------SOLD
* 2- COMPLETE model 220 Rochester, 2BBL TBI units. These are 7.4 liter units with 2" bores and flow around 645CFM ea. Easily supports up to 400H.P. with this setup!
* 1- standard spreadbore TBI adapter. Perfect for bolt-on installations. IT has been media blasted and base casting gasket area voids filled with epoxy and machined flat.
* 8- #5235231, 81PPH injectors. All good.
* 1- GM 5-pin electronic distributor (fixed reluctor for use with ECU apps.) with external coil.
* All fasteners, "O" rings, pod risers & attaching hardware for the TBI units as they are all disassembled currently.
* 2- ESC modules; 1-350CID & 1-454CID modules.
* 2- ESC/MAP module piggyback engine mounting brackets; one big and one small block.
* 4- MAP sensors.
* 4- Throttle position sensors--2 BBC, 2 SBC.
* 3- IAC (idle air control) servos.
* 1- oil pressure fuel pump relay cut-off switch.
* 1- modified fuel pressure regulator (externally adjustable) can be dialed up to around 17PSI without removing the TBI!
* 1- bag of FPR diaphragms.
* 1-bag injector grommets.
* 3- pair fuel inlet/outlet fittings; 2 with steel lines for rubber hose adaptability.
* 4- air cleaner studs.
* One complete OEM wiring harness with all factory connectors, ALDL underdash terminals, relays (fuel pump and trans.) and fuses.
* 1-bag of misc. connectors & sensors; (IAT & CTS).
* 1- brand new knock sensor (7.4 liter unit)
* 1- brand new, 2-pulse, VSS (vehicle speed sensor). This is a conversion "Stealth" screw-on unit, #2PRS, from JTR (Jags That Run) see here: http://www.jagsthatrun.com/Pages/Spe...eedometer.html
* 2- NBo2 sensors with connectors.
* 1- Innovate Technologies LC-1 Wideband Controller complete system with WBo2 sensor and updated datalogging software (Logworks 3.0). $190.00 when purchased. See here: http://www.innovatemotorsports.com/products/lc1.php <------SOLD
* All schematics, invoices and associated paperwork with one very large "D" size ECM schematic that I copied for easy visual reference.
All of these components have been organized and bagged and kept in a dry, southern California shop.
$300.00 for the whole lot or PM me with wants.
Thanx! Bud Weaver
69sixpackbee is offline   Reply With Quote
Old 02-11-2010, 11:55 PM   #2
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Re: Huge Lot EFI System With DynamicEFI "EBL Flash" 7.4 TBI LC-1 WBo2
Price?
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 02-12-2010, 12:00 AM   #3
Rooster's 67
Rooster's 67's Avatar
interested#1
and as per rules of the board....price with for sale ads?
Rooster's 67 is offline   Reply With Quote
Old 02-12-2010, 12:06 AM   #4
69sixpackbee
Sorry $600.00
Thanx,
Bud Weaver
I'll edit the post. My first for sale ad.
Long time poster and FINALLY a premium member
Old 02-12-2010, 12:07 AM   #5
wancosc356
wancosc356's Avatar
Its all good. Was just trying to help out. Welcome to the PREMIUM side!
Michael
Old 02-12-2010, 12:15 AM   #6
69sixpackbee
Thanx, Michael!
Old 02-12-2010, 01:58 AM   #7
wancosc356
wancosc356's Avatar
Originally Posted by 69 1/2 Six Pack Bee View Post
Thanx, Michael!
No problem! Good luck with the sale!
Michael
Old 02-13-2010, 03:54 PM   #8
69sixpackbee
Changed some details.
Bud
Old 02-13-2010, 05:15 PM   #9
jorgensensc
jorgensensc's Avatar
Okay, I was watching this and was a little interested, but honestly was a little confuswed by all the redundant parts. What exactly is needed to run the system? And now that you have sold parts of the system, can it still be run? What other parts would be needed to run this system. How much for just the parts needed for one system without all the extra parts? Sorry for the questions, I'm just a little confused by all the different parts.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 02-14-2010, 10:46 PM   #10
69sixpackbee
I changed the wording once again.
With all that I have left you would need an ECM from a donor truck (1227747 preferably) and components for a fuel delivery/return system. I have used Ford van, ('80's era) externally mounted style fuel pump which works well.
If you have that ability and the equip to burn PROM chips (or the EBL Flash like I had) it would be really helpful to dial in any system.
The ECU's can be had in the wrecking yard for cheap.
This is still alot of the necessary components needed. I have collected parts for SBC and BBC so that is why some of the parts seem to be "redunant"
Thanx!
Bud
Old 02-15-2010, 12:33 AM   #11
jorgensensc
What is the new price since the computer stuff has been sold?
Old 02-15-2010, 12:20 PM   #12
69sixpackbee
I updated it to $300.00 for the whole lot. I don't sell much stuff as this was the very first posting here so excuse my "newbie-ness"
