how much "Z"
i have a 84 swb stepside and wondering how much Z do i do to where i dont have to modify my steering shaft or what ever the bar is called coming out of the steering column to the gear box on the frame.
Happy to be here
![]() Join Date: Mar 2000
Re: how much "Z"
Not enough to be worth while. If your going to do a Z and not mod the steering shaft, your looking at the wrong way to lower it.
Take a look in the Suspension forum. There is a LOT of info there on this topic. Here's a thread that might be of interest- LINK
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-12-2010 at 10:27 AM. |
Re: how much "Z"
the truck is going to be bagged. i have the cab off to do the suspension work. i just dont know how expensive the steering shaft components gonna cost. kinda on a budget.
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: how much "Z"
I agree, if you're not going to mod the steering you might as well just run spindles and springs or spindles and bags.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Squarebody Aficionado
Re: how much "Z"
Im not sure if "z" the frame and stuff like that really goes with "budget" most of the time those projects are exstensive and require either a lot of fabrication or money. how low do you really want to go?
#6 | |
Happy to be here
Re: how much "Z"
I understand your concerns over doing it on a small budget. If you can not afford to buy the Borgesen joints to do the steering correctly, then a Z is not in your budget. If you can't afford to do it right, wait until you can. It amazes me how recently there has been a trend toward people Z'ing their frame because its a "cheaper" way to do it. Unless you have the skill, and tools to do it yourself, it's not a cheap solution. Please note that a poorly done Z is essentially creating a vehicle that is unsafe to drive.
Re: how much "Z"
i can do the work on the bags. thats not the problem .tools and fabrication is something that i got and have done. never done a Z or checked into it . thats why my concern is the steering shaft. about roughly how much they cost to get one made. as far as how low i plan to lay rockers.
Happy to be here
Re: how much "Z"
Sorry if I came off as presumptuous, I just hate to see a truck cut up by those that aren't capable. Since you have the ability to do the work, let me suggest some time spent in our Suspension forum as this topic has been covered many times.
Take a look here for the most common used joints-www.borgeson.com
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-12-2010 at 01:39 PM. |
Re: how much "Z"
The necessary joints and Double D shaft will run you about $200
Crew Cut
Re: how much "Z"
you might look up mike nutts build. we did a 3'' z on his 69 frame with no problems on steering but it was close.
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN ![]() |
Re: how much "Z"
thanks guys for the suggestions. and thats not as expensive everyone makes it seem to be.... now the fun part begins . it snowed pretty bad out here last night so 28* degree weather isnt to nice.. so i will load pics of progress as i go.
Re: how much "Z"
A 1 3/4" "z" will work with your stock steering, but you will only be laying frame. This was done to this truck.
Mexican |
#13 |
Re: how much "Z"
well thats not a bad look also. just debating on going the extra mile and laying rocker or just frame.
#14 |
Happy to be here
Re: how much "Z"
Thanks for sharing that info. Do you have any pics of the Z?
#15 |
It'd be alot cooler if you did
Re: how much "Z"
Ken there is a build thread on FSC.
#16 |
Re: how much "Z"
Keith at www.nfamusairsuspension.com did the work on that truck.
Mexican |
#17 |
Re: how much "Z"
yup keith at nfamusairsuspension did a 1.75'' z , notched the upper arm for the stock steering, and modded the lower arm with 8'' pipe and 2 '' deep, its also got stock ac/heat.
