Strange Problems
Alright i have a 84 chevy c10 and when i turn the blinkers on something strange happens.... both front blinkers work how they are suppose to but when i turn the blinkers one way or the other Both back lights light up. also my running/tail lights dont work and my brake lights... any help or ideas on how to troubleshoot this would be much appreciated.
thanks gavin |
Kid's Mechanic
Re: Strange Problems
That's not all that strange, Two common things to check.
Grounding,which this problem is. Should be a black wire that go's to the frame.They will windup broken or rusty at the frame Some times a good place to start is trailer plugs,I have seen some pretty bad wiring done to hook one up. Also this may help with wire color, Left turns are yellow right turns are dark green tail lights are brown backup lights are light green Grounds are black Last edited by powerdriver 1958; 02-12-2010 at 02:41 PM. |
Robert Olson Transport
![]() Join Date: Oct 2002
i agree with the ground issue but it could also be a bulb issue check the sockets to see if there is a wrong bulb in the socket a single element bulb (1156) in a double filament socket (1157) can do this or visa versa...only if someone changed a bulb recently or this truck is new to you
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! Last edited by old Rusty C10; 02-12-2010 at 02:51 PM. |
yeah this truck is new to me i traded an old rx7 for it
thanks a ton for that color coding found out why my right blinker would turn on when i turned the left one on haha they had it switched around. i regrounded and spliced in some brand new wire and its all good to go thanks guys.
