Old 02-12-2010, 05:19 PM   #1
smoked68
smoked68's Avatar
496 stroker in 68 sbc
What do I need to expect in putting the BB in my truck. It now has a 350 w/Weind roots SC, (144 ci). What about motor mounts, oil pan etc...Do i need solid mounts. Headers?? We will need 1 7/8'' primaries, where do we find these?We are expecting 700 + hp with a Procharger. Thanks for the input ahead. Mike
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 02-12-2010, 10:06 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: 496 stroker in 68 sbc
You'll need big block towers and mounts at least.The Pan from a big block truck should work fine but you may look around and find an aftermarket high capacity.There should be someone chime in on the headers but you may want to go with shorties if you are lowered since full length ones sometimes set below the frame rails.Someone more knowledgeable can probably tell you what they are running.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-12-2010, 10:41 PM   #3
AusTx68
AusTx68's Avatar
You are fine using the stock BBC oil pan.
If you are looking for aftermarket parts these mounts work fine.
http://www.performanceonline.com/sto...cat=455&page=1
For headers these Clipsters are a good choice:
http://www.summitracing.com/parts/PTE-H8013-1/
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 02-12-2010, 11:59 PM   #4
ripdog28
ripdog28's Avatar
I got the ECE tubular motor mounts. I have Hooker 2in primaries that took some dimpiling to get to fit. I would get rid of the 12 bolt or get it seriously worked over. Check out my build in my sig for more info/pics.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 02-13-2010, 09:39 AM   #5
smoked68
smoked68's Avatar
Thanks so much for the input guys. Thats exactly what I was looking for. And yes we are going with a 9" and 4 link air ride. Currently were running a m-21, I was going to get a TKO 600 tremec but not so sure now. Looking into a auto but where can I find one to handle the hp? Thanks, Mike
Old 02-13-2010, 10:46 AM   #6
ripdog28
ripdog28's Avatar
You can call any of the major trans companies for a 350/400 that can handle 1k... or look for a local shop that may be able to.
69 c-10 BBC
Old 02-13-2010, 12:29 PM   #7
kgt
i have a 68 c-10, i used hooker super comps, 2 inch pri/3.5 inch collectors. cleared everything, used smallblock mounts , frame stands ect, had to dimple the drivers side frame tower. I used a 1/4 inch'ish(lol) shim under the motormount for clearance. No dimpling of the headers. The only issue i have is when i built my 3 inch exhaust i had to use a s bend pipe with a 3 inch offset to clear the crossmember to allow the pipe to pass through in the correct saddle area in the trans crossmember...
kgt is offline   Reply With Quote
