PROJECT 7DEUCE
![]() Join Date: Dec 2002
Arm Swap
Can you swap the rear trailing arms from one side to the other,so that the e-brake would run along the insise of the trailing arm ....Has anyone done this or seen it done???
THANKS LUKE
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Fabricate till you "puke"
its been a while since I looked at those old trailing arms.....but arent the E brake brackets riveted to the arms?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
PROJECT 7DEUCE
Yes they are rivits are a pain in the a$$...I saw a 66 at the body shop i was at that had them inside the arms but the guy had no clue cause the truck was built for him ..
I never really thought about it, but the arms are straight.... they probably would swap side for side. my thoughts were that it would be less work to cut the rivets, & just swap the brackets/bolt them back on. crazyL
PROJECT 7DEUCE
Ya it is alot of work but i have to pull the arms back off to replace the bushings so no big deal ....I guess i would have to figure out the cable routeing or maybe run a lokar e-brake set up .....Im gonna give it a shot saturday i think it would be clean if it would all work out....
