how low can i go?
i have a 70 short fleet wood bed with a cpp c-notch, and wanted to know if it would be worth the work raising the floor to get full use of the notch. how low can i go without raising the floor. anyone have pics with bags, c-notch, 20's and stock height floor. thank you
Re: how low can i go?
ttt
I Like Mine With No Shine!
![]() Join Date: Apr 2009
Might try using the search function. I believe this question has been asked numerous times.
Michael ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=384152 Last edited by wancosc356; 02-14-2010 at 04:30 PM. |
67-72 parts collector,…
![]() Join Date: Nov 2002
I'm at 5.5"/7.5" static drop on my '69 swb.
![]() Join Date: Jul 2003
How did you get that static lolife? That is exactly where I want to be, I have a 71 1/2 ton with 3" spindle, 1" spring, 4" leaf and 1.5" shackle, (disassembled). I may need to re-do this thing.
#6 | |
Tot Roddin'
http://67-72chevytrucks.com/vboard/s...hlight=no-life And the suspension is made up of: '71-72 drop spindles 3" springs (front) 6" springs (rear) 1.5" lowering blocks
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#7 | |
Tot Roddin'
If you only go with a static drop, a 4.5/6" drop will be as low as I would go in order to run 20's; unless the specs were spot on and accounted for turning radius and suspension travel, you might be able to go a tad lower, but not without notching the rear as you have done. For the specs you mentioned above, any standard bag system will allow you to lower the truck as far as possible without major modification.
#8 | |
front: 2.5 spindle 3" drop spring rear: 6" drop spring 1.5" lowering block You might need stock rear leaf springs and a flip kit to get the back this low. (and maybe a lowering block) You can always trim your front coil springs to lower the front a little more. |
One day.....
Heres mine. Bagged with a bolt on CPP notch on 15" rallies. Stock bed floor.
DZL1. Last edited by DZL1; 02-14-2010 at 09:33 AM. |
dzl1 are you maxed out on the notch or do you have a bigger bump stop so you dont hit the bed floor
You would need bags and 2" blocks to have to utilize the whole notch. You would also have to cut out a small section of the cross member above the differential because the nose of the diff will hit it, and then you'll only gain an inch. This requires raising the floor. If I had to do it again I wouldn't. If I were going to do this much work you might as well try to lay frame. This is my experience with the weld in arch notches.
Redefining LowBudget
ok bagged with a 2 1/2" c notch and cupped LCA
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#13 |
heres mine - bagged with 3" spindles, cut bottom cups down with upper plates, 2" blocks, 2 1/2" c-notch, stock floor with stock inner fenders front and rear
#14 |
This is about as low as you can go, the pumpkin is within about 1/8" from the bed floor when it's sitting on the airbag bumpstops. I also have some block too.
#15 |
Lots of good info here, and some very sweet trucks, I do have more questions. With only a cpp notch (no dropmember) what will hit first? Pumpkin on bed, driveshaft on crossmember or axle on notch? Given that there are no bumpstops. Some one should know this...
#16 |
With a 2" block,... I would say "pumpkin hits the floor".
#17 |
mine was either the floor or the crossmember
#18 |
One day.....
#19 |
bump stops ?? what are those..My lca hits my x memeber at full dump and the rear axle bottoms out on the c notch and the pumpkin is so close that with my old bed ( junk floor) if you bounced on the floor you could feel it hit.....both are ok as long as you go slow ( like in a smooth parking lot) but about 2" of clearance is all I ever have to the stops..keep in mind also that you have to drive your truck that low or you'll hit very thing and if your running long headers they take it hardest..
#20 |
crazy question i know but what does static mean?
#21 |
motor exploder
static is a drop with regular coil or leaf springs - i.e. non adjustable.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
