Old 02-13-2010, 12:28 AM   #1
gavinmosher
Wanting as much info on Bag setups as possible
Alright guys just got all the wiring figured out on my 84swb now to the fun stuff... cosmetics.... i want to do a airbag setup what size notches should i use what size bags etc etc i dont want to do anything extreme like "z" the front i just want the most imformation i can have before i start buying stuff left and right... i know i sound like a newb on this.... but thats only cuz i am haha.... i have never done airbags on anything and i figured why not?? thanks guys
Gavin
gavinmosher is offline   Reply With Quote
Old 02-13-2010, 01:54 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Wanting as much info on Bag setups as possible
Tell us about your gaols. How low do you want the truck to be? This will help us guide you in the right direction.
Take a look at our suspension forum. There is a LOT of good info to read up on there.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-13-2010, 02:46 AM   #3
gavinmosher
i just want to be able to sit it down on the frame rails if that is acheivable without anything major done... i just want to be able to be low when i can and lift it when i need to because the roads around her suck but i like the low trucks.
Old 02-13-2010, 07:17 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Look around here.
www.porterbuiltstreetrods.com.
Ken's right,... look in the suspension section.
There's a bunch of info there.
Old 02-13-2010, 08:17 AM   #5
andrewmp6
To lay frame a front and back dropmember are your best bet but you'll have to do some worth.
andrewmp6 is offline   Reply With Quote
Old 02-13-2010, 02:50 PM   #6
oldschool18
oldschool18's Avatar
to figure out how big of a notch you will need is pretty simple, measure from ground to bottom of your frame in the middle of your truck. lets say you got 9", then measure from the top of your axel to your frame. and lets say you got 5". so thats 4" diff, plus you got to add in the bags most are around 3" compressed but you want that info before you start, and you got to find the bag brackets you are going to use. I forget what mine are but I will measure them tomorrow and let ya know. but you want a bigger bag for the front, the front is easy to do, I made my own set up. but check around for the rear look at alot of pics and get the style you want, depending on where you put the bags meen alot, ride quality, or if your going to be towing and ect. I got my bags from airbagit.com and theres alot of forums on there to look at too.
oldschool18 is offline   Reply With Quote
