Old 02-13-2010, 01:47 PM   #1
heymoe
heymoe's Avatar
Could use some help.
I am looking for the lower control arm u-bolts and axle u-bolts to mount the rear end. The parts stores here in Cincinnati do not seem to carry these.... because there computer doesn't list them the do not have them.
Anyone in the Cincinnati, Middletown area know were I can pick these up? I have tried Napa, Savage, Autozone, Advanced Autoparts.
heymoe is offline   Reply With Quote
Old 02-13-2010, 02:15 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Could use some help.
try a spring shop and they can make them for you.
hayhauler71 is offline   Reply With Quote
Old 02-13-2010, 03:36 PM   #3
cdowns
cdowns's Avatar
i'd try a different parts store that has an old guy that knows how to read a book
Old 02-13-2010, 03:45 PM   #4
71swb4x4
71swb4x4's Avatar
Any quality spring or alignment shop will have the ability to make the u-bolts. Try truck shops too.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-13-2010, 03:54 PM   #5
71 super
71 super's Avatar
Any parts store that has a "help" section should have the front u-bolts for control arms, were also still a GM part a couple of years ago- they are larger in diameter because of some breakage issues expect to pay 5-8 bucks each. The rears check with a spring shop or some of the larger scale venders on here. Also try teeitup as he may have some out already and he will do you right.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 02-13-2010, 08:21 PM   #6
72BLUZ
72BLUZ's Avatar
order from LMC
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 02-13-2010, 08:49 PM   #7
MAK191
I just purchased the front and rear in the last couple weeks. you need this a for the front(napa part BK 6504065) and I went to a local spring shop for the rears, http://67-72chevytrucks.com/vboard/s...d.php?t=384759 but it depends if you are going to add blocks. 3/4"x3.5"x8" for stock.
MAK191 is offline   Reply With Quote
Old 02-13-2010, 08:52 PM   #8
OhOneWS6
OhOneWS6's Avatar
I got mine from Early Classic Enterprises.
OhOneWS6 is offline   Reply With Quote
Old 02-14-2010, 09:39 AM   #9
heymoe
heymoe's Avatar
Thanks everyone. So the newer lower control arm U-bolts are a larger diam. than the factory? What about center to center. I may just measure the ones I have and see if Mcmaster carr or grainger has them also.
Big help guys.
Thanks again
Old 02-14-2010, 10:58 AM   #10
OhOneWS6
OhOneWS6's Avatar
Big help guys.
Thanks again
They are the same dimensions, just made out of larger diameter stock. They are actually the ones used in the 73 up trucks. You may have to drill out the holes in the cross member just a little to get the larger bolts in. I had to drill out about half of the holes in mine. You can probably find them local if you look for the ones for 73-87 trucks.
Old 02-14-2010, 11:05 AM   #11
rockc
Classic heartbeat had some at a reasonble price
72 chevy 3/4 ton 4X4
rockc is offline   Reply With Quote
Old 02-14-2010, 11:54 AM   #12
big blue 72
check out Dsuban Springs here in Fairfield. not far from my house off of Rt. 4
Broken Back Club
72 Club
GMC Club
Panel truck Club
6 cylinder Club
Unfinished Projects Club
Outdoor Sportsmens Club
big blue 72 is offline   Reply With Quote
