02-13-2010, 04:02 PM | #1 |
PROJECT 7DEUCE
Self bleaders....... brakes
I bought a set of self bleaders that screw into the bleader holes for my disk brakes my question is can I just leave them in there? Or should I just replace them with the originals?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
02-13-2010, 05:13 PM | #2 |
Re: Self bleaders....... brakes
Leave them in there.
02-13-2010, 05:43 PM | #3 |
PROJECT 7DEUCE
Now the next question since I got that figured out and done. With the rear brake line detached from the prop valve when i pump the pedal I should get a steady stream of fluid correct? Not just dribble dribble..
02-13-2010, 06:03 PM | #4 |
You should get a steady stream of brake fluid. Why do you have the line off at the prop. valve? I am having trouble getting the brake line off of the rear brake hose. It connects in side of the frame. And it is hard to get to. I have been trying to soak it with penetrating oil. The rear hose is the only old part on the brake system. I may have to replace the line from front to the rear. Good luck . Grady
One more thing. Don't let up on the brake pedal with the line off. You will suck air back into the master cyl. Last edited by grs; 02-13-2010 at 06:06 PM. |
02-13-2010, 06:12 PM | #5 |
PROJECT 7DEUCE
I took that line off cause I was not getting fluid to the rear brakes and im just getting a slight drizzle from the line soooo id guess I need a new master cylinder...
02-13-2010, 06:41 PM | #6 |
maybe read a service manual about how to bleed brakes properly and centering your pin
02-13-2010, 06:45 PM | #7 |
PROJECT 7DEUCE
edited....
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 02-13-2010 at 06:46 PM. Reason: no reason just reading the service manual... |
