Old 02-13-2010, 04:17 PM   #1
Dusty71blazer
Dusty71blazer's Avatar
Need a shortcut!!
I just got new "K/5 Blazer" emblems & need to install them (factory holes are there).
Is there an easy way to get at the inside of the fender to install the nuts? Do I have to remove the fender completely?
Any suggestions?
Thanks!
Dustin
'97 Dodge Ram (daily driver)
'71 Blazer (supposed to be a toy... insists on being a project)
'85 Monte Carlo SS (project)
Dusty71blazer is offline   Reply With Quote
Old 02-13-2010, 04:40 PM   #2
mr48chev
mr48chev's Avatar
Re: Need a shortcut!!
You might try taking the inner fender loose and drop it down enough to get your hand up in there.
Old 02-13-2010, 05:05 PM   #3
SeventyOne
Any suggestions?
Thanks!
Just give up and send them to me. Problem solved!
SeventyOne is offline   Reply With Quote
Old 02-13-2010, 05:18 PM   #4
blazerboy72
Most parts stores carry something that I believe is called a speed nut ( not certain on the name) it just inserts into the hole and then you push the emblem prong into it. This is how I did mine. Im not certain how you remove them since I havent had a need to.
blazerboy72 is offline   Reply With Quote
Old 02-13-2010, 05:55 PM   #5
NuBomb
NuBomb's Avatar
Is it a barrel clip? They make some round clips that go inside the drilled holes and stay in place and accept the emblem studs.
Jeremy (NUBOMB)
72K5 CST 350/350/205
1951 Chevy 1/2 ton
North Georgia Group
"... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman.
NuBomb is offline   Reply With Quote
Old 02-13-2010, 06:04 PM   #6
blazerboy72
Possibly it has been so long since I have used them I have no idea what they are called.
Old 02-13-2010, 06:48 PM   #7
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
You need extremely skinny arms & remove the inner fenders. The drivers side is easier than the passenger side.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-16-2010, 03:05 PM   #8
Dusty71blazer
That's what i was hoping to hear!!
Do the holes need to be drilled out to use these?
I'll check with the parts stores as soon as I can..
Dustin
Old 02-16-2010, 04:47 PM   #9
blazerboy72
no they were a perfect fit in the original holes. I can get the name off of the pack tomorrow if you need it.
Old 02-16-2010, 06:55 PM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
I'd be interested in the name off the pack - I tried to use some a while back but they didn't grip the emblem studs very well.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-17-2010, 09:09 PM   #11
jamie72
jamie72's Avatar
got mine at napa, used them just this fall,work great!! i believe there 3/16 and they also work for holding the rods in your tailgate handle....
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 02-18-2010, 10:40 PM   #12
Dusty71blazer
Picked some up today & got my emblems installed in just a few minutes!
They worked great!
Thank you for the help!!
Dustin
Old 02-18-2010, 11:16 PM   #13
Big J
Its lookin' like a Blazer!
Big J's Avatar
They worked great!
Thats awesome, post some pics of them installed along with the parts and a part number. It could help someone in the future. When ya get a chance of course.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 02-18-2010, 11:32 PM   #14
Dusty71blazer
I tried to get a picture but I have too much crap in the garage, hard to get a nice picture.. maybe I'll be able to get it out of the garage this weekend.
Dustin
Old 02-19-2010, 10:46 AM   #15
Yukon Jack
Post Whore
Yukon Jack's Avatar
Got a part number of the ones you used Dustin?
Old 02-19-2010, 11:53 AM   #16
lks dcvn
lks dcvn's Avatar
Are they rivnuts?
lks dcvn is offline   Reply With Quote
Old 02-19-2010, 04:19 PM   #17
Dusty71blazer
The bag just says for 3/16" stud
The parts counter guy called them insert nuts, he knew what I was looking for right away so I assume they are reasonably common. I got them at Arnold Motor Supply, they are an Auto Value franchise- $5 for 10 of them, I went there since they have alot of auto body supply stuff. Here's a pic..
Hope this helps!
Dustin
Old 02-20-2010, 11:51 PM   #18
joeelutz
joeelutz's Avatar
Most people call them barrel nuts.
joeelutz is offline   Reply With Quote
