Old 02-13-2010, 07:32 PM   #1
chevroletman223
Dan
chevroletman223's Avatar
WTB: Crankshaft Pulley
Hi guys, i am in need of a double groove crank pulley for a small block. Need it for my power steering conversion. If anyone has one, please give me a price, and diameter. a picture would be nice too. Thanks! Dan.
1968 C10 Short Fleet - L79 327, th350
1971 Nova - 327, Th350, 3.73 posi
1971 K10 Short fleet - 350/350
1971 K20 longbox - 350, 4spd
1970 Chevelle, Tunnel ram set up 355, th350
1986 C30 Dually, 454/400
1967 Impala 4 door hardtop, Supernatural clone
1968 Camaro, 327, pwerglide
1967 camaro, numbers match 350, powerglide, bench seat car
1968 Nova, Numbers match 6cyl, powerglide
1968 Nova, 327, th350
1970 Impala, 350, Th350
1968 Impala, Numbers match 350, Th350
1971 Chevelle SS, Numbers match 350, muncie
chevroletman223 is offline   Reply With Quote
Old 02-13-2010, 10:45 PM   #2
nplocoman
never finish start another
nplocoman's Avatar
Re: WTB: Crankshaft Pulley
try this 270531185148 on ebay I needed the same thing. I bought one for about the same price. Mine came a little cleaner but they are cast iron and will look just fine with a wire brush and spray paint. Hope this helps. works perfect with the double groove pulley on the front. gives you 4 grooves the third will match the pump pulley.
nplocoman is offline   Reply With Quote
Old 02-13-2010, 11:31 PM   #3
chevroletman223
Dan
hmm im not sure now. if i added that pulley you showed me to a single groove would it work?
Old 02-14-2010, 12:04 AM   #4
ironhill
ironhill's Avatar
I have a double grove crank pulley if you are interested. Its the same as the single grove but is of coarse two groved. If you are interested I'll get you a pic in the morning.
ironhill is offline   Reply With Quote
Old 02-14-2010, 12:06 AM   #5
ironhill
ironhill's Avatar
Thats Groove its getting late
Old 02-14-2010, 12:33 AM   #6
chevroletman223
Dan
Thanks for your help guys, im going with one on ebay
Old 02-14-2010, 06:19 PM   #7
nplocoman
nplocoman's Avatar
The one on ebay will work. If you have a single on now you will end up with a gap between the two pulleys but it will still work.
Old 02-14-2010, 06:38 PM   #8
chevroletman223
Dan
Thanks nplocoman, will i need longer bolts? if i remember correctly they are pretty short bolts
Old 02-15-2010, 06:28 PM   #9
nplocoman
nplocoman's Avatar
Yes, you will need longer bolts by 1/2 inch. They are 3/8ths fine thread.
Old 02-15-2010, 06:48 PM   #10
chevroletman223
Dan
Thanks again nplocoman!
Old 02-15-2010, 07:15 PM   #11
nplocoman
nplocoman's Avatar
If you don't have them out yet, just get some 1 inchX 3/8ths with lock washers. Fine thread!
