Transfer case questions!!!
OK....I am having a devil of a time finding the right transfer case for my 91 burb. I have installed a 1997 7.4 vortec in the sled and am ready to put in a 96 4l80e tranny. I have been looking to trade the current 96 np243-c for a np241-c with a 32 count input spline in which there seem to be plenty of but not with a passenger side drop. And of course I need the passenger side drop. Which leaves me with pretty much one vehicle and 2 model years. A 3/4 ton 1990 or 91 suburban with a TH-400. My question is I see quite a few NP208 and 205's available....I know I would need a adapter plate...but how would I adapt them to use electronic sending for the speedometer on the dash(is there a add-on option) and what else electrical/mechanical is missing from those units that the np241-c has? Sorry if I have confused anyone.....but I am getting frustrated.
Grease Monkey
Re: Transfer case questions!!!
is there a way to connect your speedo wire to the transmission instead?
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
#3 | |
![]() Join Date: Jul 2009
So do yourself a favor, call advance adapters first and ask for Vic.. He helped me, explained everything clearly, and gave me a coupon code to boot. I won't get around to installing mine for another few weeks as we have to test the engine first on a homemade test stand and make sure everything is good before I waste more time installing an engine that may have unadvertised problems... For me, getting the kit was cheaper than startng all over and looking for another set of modern axles with a driver side drop.. I like my Dana 44 so $278 vs. $400 for another axle and another Tcase for $300 makes sense..
******************************************** In-work on my 5.3L/4L65E/NP208 case conversion into a 1972 GMC JImmy 4x4... Not as simple as it looks folks.. ![]() Last edited by amcgeh01; 02-14-2010 at 03:39 AM. |
I have what you need. I pulled it from a 91 3/4 ton Burb with a 4l80 and 241 t-case. Adaptor and tranny. Tranny is the 241 with pass drop and VSS. Will need the VSS sensor, it got smashed moving it around, but the one out of your tranny will work.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS Last edited by powerdriver 1958; 02-14-2010 at 11:25 AM. |
Let's not turn this into a Want to Buy thread guys.... he's asking for advice, not parts, right?
we all know the rules and you must be a paid subscriber for that.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
to throw yet another idea. If you can find a dodge divorced 205 then you can run a 2WD trans (4l60 or whatever will match your engine/ecm) and then the 205. i just bought on in WI for $100 and that's my plan.
time is inversely proportional to money; that's why it takes me so long 1967 K10 1967 Camaro |
#7 | |
I really think that amcgeh01 has your solution. I also had a 98 4L80E that I had wanted to rum a NP205. I called AA and they seemed very familiar with the difficulties in that combo and had all the parts and answers that I needed. It was a bit pricey at the time so I never did it but they do have the stuff.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
I went through the same dilemma. I first bought a np241 pass drop. rebuilt the dana 44 and was concerned about the strength with the BB 427. I decided to go with the BW4401 Tcase from my 95 1 ton donor. I then found a 95 ford dana 60 drivers drop that I am picking up tomorrow.
Don't know if any of this helps. Doug
68 CST 396, 60K original miles 70 Longhorn project 72 Stepside (150% complete) 67 Stepside project 71 RS Camaro 90% done 71 BB Corvette 50% complete 78 K5 project |
![]() Join Date: Feb 2009
You can use a a transfer case from a 90 or 91 K5 Blazer/Jimmy. It is a 27 spline pass drop. But you can buy a new 32 spline input gear.
I just put a 241 from a 90 Blazer behind a 1997 4l80E. Another bonus is the Transfer case is already setup for VSS. Only 90 and 91 Blazers had them. Swapping the input gear was easy and cost $85. |
you guys are all fantastic.....I'll have to see my options.
