Core support
Anyone know if you can use a 67 core support on a 70? What mods need to be done to make it work?
Tot Roddin'
Re: Core support
You can but I believe the headlight/grille mounts are different. Are you changing the entire front end or just the support?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Re: Core support
I'm just changing Support. The 70 one has light bezel mounts that protrude a little and the 67 doesn't. I'm thinking i can drill the spot welds and just tack them on the 67 core support cause everything else looks the same.
