Old 02-13-2010, 10:45 PM   #1
cplkillian
Carb Questions
I have a 71 w/ a 350 quadrajet and i am going to be changing the manifold and carb to edlebrock, and the carb is going to be an electric choke. are there any problems in making it an electric choke, my carb now is not a manual, but i saw on the new carb that it has 2 wires. any help will be greatly appreciated.
Mike
cplkillian is offline   Reply With Quote
Old 02-13-2010, 11:09 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Carb Questions
No problems with an electric choke, just hook it up to 12 volts and go. The choke on Edelbrock carbs ground to the carb.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-13-2010, 11:13 PM   #3
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Re: Carb Questions
One wire needs to run to chassis ground (ie any part of the carb or intake should ground) and the other to a switched hot wire. There should be a spare terminal on your under dash fuse panel that is hot when the ignition is switched on. I would wire an in line fuse and run it to your carb. Another option would be if you've already changed from a points distributor to a HEI, the HEI will have a switched hot wire run to it. You could splice into that wire.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 02-14-2010, 10:56 AM   #4
cplkillian
Re: Carb Questions
thank you both, great info.
Old 02-14-2010, 11:22 AM   #5
Wrenchbender Ret
Re: Carb Questions
The only thing you have to watch for with that system is if you leave the key on without the engine running the choke will go off. The factory system uses an oil pressure switch. It,s no biggy but something to keep in mind.
Wrenchbender Ret is offline   Reply With Quote
Old 02-14-2010, 04:53 PM   #6
cplkillian
Re: Carb Questions
thanks wrench.
i also am wondering, im wanting to replace the distrbutor while its all blown apart, and was curious what hei distributor i could get. mainly what years. i was looking at the mid 80's ones but want to make sure its something that will work
Old 02-14-2010, 05:06 PM   #7
Wrenchbender Ret
Re: Carb Questions
A v-8 HEI from 75 up to early-mid 80's will work. Some in the 80's have computer controls. Make sure it has mechanical & vacuum advance. I always get a used one & fix it up, but a lot of guys are buying the new ones.
Old 02-14-2010, 05:07 PM   #8
Sinister
Between Trucks...
Sinister's Avatar
Re: Carb Questions
I would get a Skip White HEI off of E-bay. Plenty of guys on the Board running them.
Beat it to fit,
Old 02-14-2010, 07:16 PM   #9
cplkillian
Re: Carb Questions
sinister, thanks i looked him up, and seems like a killer deal.
Old 02-14-2010, 07:44 PM   #10
Sinister
Between Trucks...
Sinister's Avatar
Re: Carb Questions
Yeah, it's a real good deal. Good luck with your truck.
Beat it to fit,
Old 02-14-2010, 10:36 PM   #11
aintmisbehavinn
Re: Carb Questions
Someone put a Holly manual doublepumper on mine, gas miles = 12 if I'm lucky.
aintmisbehavinn is offline   Reply With Quote
Old 02-14-2010, 10:39 PM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Carb Questions
Most cases a double pumper on a small block street rig is overkill...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-14-2010, 10:57 PM   #13
aintmisbehavinn
Re: Carb Questions
Gary
I found out the hard way when it turned a 13.28 quarter mile. The only good thing I see is I don't have to choke it to crank it....I also noticed it has TRW, MSD, Lunati, Weiand, Flowmasters, B&M and other goodies, probably overkill as well but it sure feels good when it stalls to 2400 then leaves rubber half way down the track and everyone else is playing catch up with the LWB truck.
Old 02-15-2010, 01:52 AM   #14
cplkillian
Re: Carb Questions
i was comparing the stock intake manifold and the new edelbrock one and noticed that the new one has 3 coolant ports that are threaded and the stock one has one. can i plug those, or is there anything im missing?
Old 02-15-2010, 09:58 AM   #15
Old Yeller 1970
DON'T TREAD ON ME
Re: Carb Questions
You're not missing anything. Plug the ones you don't need.
Old Yeller
Old 02-15-2010, 10:40 AM   #16
68Stepbed
68Stepbed's Avatar
Re: Carb Questions
12mpg out of a double pumper? Dang, That's good!!!
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-15-2010, 10:46 AM   #17
cdowns
cdowns's Avatar
Re: Carb Questions
best thing to do is read instructions included with your new stuff b4 installing
Old 02-15-2010, 11:21 AM   #18
fdbdw
fdbdw's Avatar
Re: Carb Questions
make sure you use locktight on the intake bolt threads or you will have oil and antifreeze coming out of them, I use the blue and it works well
fdbdw is offline   Reply With Quote
Old 02-15-2010, 01:24 PM   #19
cplkillian
Re: Carb Questions
ok i have everything ready to be put on, pulled everything off and I'm about to start the install after cleanup, as far as the fuel line goes, what am I suppose to do? the quad goes on the front and the edelbrock does not. i went and looked to see if there were different fuel lines that i might should have bought and didnt find anything, any suggestions.
Old 02-15-2010, 03:08 PM   #20
Sinister
Between Trucks...
Sinister's Avatar
Re: Carb Questions
Not necessary, but I'm running one of these: http://www.summitracing.com/parts/SUM-G1532/
I used a tubing cutter and cut the stock metal line and ran a short piece of rubber fuel line to the chrome piece. You could basically do the same with out the chrome line and run straight to the carb.
Beat it to fit,
Old 02-15-2010, 03:41 PM   #21
cdowns
cdowns's Avatar
Re: Carb Questions
buy a length of metal tubing at an autoparts store and take the time and effort to bend it for a nice safe good looking fuel line//dont use lengths of rubber hose they burn things up in the long run
