The Crazy Machanic
1986 siverado tras swappin
What all do i need truck has a small block 400 in it so id like to drop the rpms for the high way. so out goes my 3rd th350 (broke last two in a week each)
i think i just got a 700r4 (was told it was th350) but its not electric connection on side and no vaccum modulator. If any one can tell me were to look for numbers on any info for that let me know KNow here is what i know i might need to do this swap let me know if im off 1. transmission 2. shift linkage (do i need any thing for it to work for carb on kick down or will one form th350 work) 3. cross member 4. driveshaft (im sure mines to long) 5. instrument cluster 6. steering column 7. will in need any thing for that electric component to the side ive read its for lock up 4th gear converter please help i need a list before i got to junk yard
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() |
Addicted to Rust
![]() Join Date: Dec 2009
Re: 1986 siverado tras swappin
Lots of good info on the 700 around. First ? why are you breaking th350s
A stock 700 isn't very tough. A built one will give you good service, just not at junkyard prices.The shift linkage will move back and possibly need a new rod. The cross member should slide back. The drive shaft will need to be shortened. 700s were available with a cable out put so your speedo will work but will need a ratio adapter to be right. You can get by with the stock column, the indicator will not be right. Several people make lock up kits in the 60-75 dollar range. jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
The Crazy Machanic
as to the breaking th350s im not really sure my first one did amazing. but i got a little sloppy and some trans bolts to engine broke cracking the case. the 2nd one i had rebuilt came from a 76 1 ton it just didn't seem right but drove it any way went to pass some one and broke the planitary gear into pieces (i think the guy reused to old one) i had it redone again but the same guy again think must been a fluke but after i got it back truck just would not go did every thing to fix it then snap all i had was forward gears (but now it would go forward and actually respond)
reason for the 700r is my engine does not like highways with one 3 gears even tho i despise these transmissions thought id give them a shot i do have a plan be i have a 79 c60 that is manual i was trading its 5 speed for a 5 speed for more of a c30 (c60 trans has that 2 speed rear) thinking they are different. but thinking most of the manual components should line up all i should need is the trans tunnel any one else got any ideas
