Old 02-14-2010, 02:18 AM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
I gotta leak, what will fix it?
Until I figure out where I'm going to put my compressors and tank, I have run the bag lines to push on fitting with schrader valves. one schrader valve per corner.
Anyway one of the lines is leaking where it attaches to the fitting. I swapped the fitting for another, but still leaked.
How do I fix this?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 02-14-2010, 04:16 AM   #2
andrewmp6
Re: I gotta leak, what will fix it?
If the fitting a push on or screw on ?
andrewmp6 is offline   Reply With Quote
Old 02-14-2010, 07:56 AM   #3
shaneo2112RUSH
Junior Member
shaneo2112RUSH's Avatar
Only thing that comes to mind on a push on fitting is that the hose is cut at an angle to were its not sitting flush! Cut it strait as you can with a razor! I would not recomend cutting air line hoses with side cutters, they leave a V cut and can cause leaks. Also use a spray bottle with soap and water to check lines,fitting and also the air bags for leakage also!! On the schrader valves! might want to check the valve to see if its seated properly too! Local auto store should have a tool that tighens them also
1968 LWB C10 "Project LADY EYE SORE" (She is my baby and sent me to the hospital 3 times for eye injuries lol) who said love hurts??
shaneo2112RUSH is offline   Reply With Quote
Old 02-14-2010, 01:08 PM   #4
jugernot
Life, Be In It.....
jugernot's Avatar
the hoses push onto the fitting. the fitting screws onto the schrader valve
Old 02-14-2010, 01:20 PM   #5
Shane
Shane's Avatar
shaneo hit the nail on the head ... make sure the tubing is cut square ... use a razor blade or if you have a Harbor Freight close by you might consider one of these ... they have them for less than $5.00
Shane is offline   Reply With Quote
Old 02-14-2010, 09:16 PM   #6
jugernot
Life, Be In It.....
jugernot's Avatar
Yep, That fixed it. I got all the bags hooked up and post some pics on my build thread.
Old 02-16-2010, 01:49 AM   #7
shaneo2112RUSH
Junior Member
Sweet! Have fun building! and dont forget to show some pics of the build!
Old 02-16-2010, 11:41 AM   #8
dv8customs
dv8customs's Avatar
Do you have Push To Connect fittings or are they barbed fittings? I ask because you say the hoses push onto the fittings instead of into. If it is the latter I would not recommend running the barbed fittings.
dv8customs is offline   Reply With Quote
Old 02-17-2010, 08:09 PM   #9
jugernot
Life, Be In It.....
jugernot's Avatar
I was thinking about installing hard lines and use fitting from www.swagelok.com
Old 02-17-2010, 08:32 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
Swagelok stuff is nice, but expensive. We use it at work.
Good stuff.
Keith
Convert to disc brakes.
