Old 02-14-2010, 01:35 PM   #1
66coffin
66coffin's Avatar
spindle question??
do any of you guys know if the '84 3/4 ton chevy front spindles are the same as the 1/2 ton spindles? i have 3/4 ton spindles and want run 1/2 tonrotors to get a 5 lug instead of the 8 lug i have. thanks guys.
'66 c10ish straight 292 power!
66coffin is offline   Reply With Quote
Old 02-14-2010, 04:15 PM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Arrow Re: spindle question??
Im not 100% sure of this but i think the 3/4 ton spindle has a larger axel shaft than a 1/2 ton this is why it will handle heavier loads.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 02-14-2010, 05:20 PM   #3
grinch4om
dang its hot
grinch4om's Avatar
ball joints are different....find a donor truck, change the spindles and lower control arms
grinch4om is offline   Reply With Quote
Old 02-14-2010, 05:53 PM   #4
kelgar50
kelgar50's Avatar
Buy a set of 3/4 ton drop spindles from early classic they are made to take the 5 lug rotors and use your existing a arms,ball joints and steering links...plus you get a 2 1/2" drop.
kelgar50 is offline   Reply With Quote
