Old 02-14-2010, 06:20 PM   #1
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Help! Door won't open
Yes, it's unlocked.
I put EFD's weatherstrip on this weekend, then did some adjusting of the door mount. The final step was to adjust the striker plate. Guess it needs more adjusting.
I can watch the linkage move both with the inside and the outside handles. Once the arm hits the star wheel, it stops dead. Is there a way to loosen things from inside the door, so that the wheel unlocks? I'd rather not beat on the mechanism from the outside, but that may be next.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 02-14-2010, 07:14 PM   #2
zeeklu
Re: Help! Door won't open
Sometimes if you push the door shut and press the button it will open. Sometimes you have to push really hard. Chris
zeeklu is offline   Reply With Quote
Old 02-14-2010, 09:27 PM   #3
68 Stepside
huh?
68 Stepside's Avatar
Yep, I ran into this when I had new weatherstripping on the 68. I had to lean on the door extremely hard to lock it or unlatch it. Try that.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 02-14-2010, 10:10 PM   #4
weircc
weircc's Avatar
pretty sure striker is out of adjustment just get inside from the other side and push like hell it will open
weircc is offline   Reply With Quote
Old 02-15-2010, 09:32 AM   #5
hounddogs!
hounddogs!'s Avatar
Pushing like hell didn't get it. The door stopped with one of the tips of the star wheel on the tooth of the striker, rather than dropping down into the valley. Fortunately, I could get a punch against the wheel and get it kicked over. Thanks for the reponses.
DD '09 Pilot
Old 02-15-2010, 10:50 AM   #6
cdowns
cdowns's Avatar
work abit more on your alignment and dont forget that latches like lubrication
Old 02-15-2010, 01:55 PM   #7
hounddogs!
hounddogs!'s Avatar
Raised the striker 1/8" and all is well. Lube is done. Thanks guys.
DD '09 Pilot
