The Crazy Machanic
cant find any straight answers 700r4
Ok i got a 700r4 to install in my 86 c10 2wd currently has a th350 but what on earth does the wire connection on the side do. i have heard its a temp sensor and speed sensor. I've also heard its a torque converter lock out but i really need to know so i don't kill this trans.
sitting in front of the 350 is a nicely built small block 400 that seems to be a whole other world to its cousin the 350 please help these trans scare me
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() |
Re: cant find any straight answers 700r4
torque converter lock up.
you dont need it if you do a dummy lockup converter. you can still utilize the 4th gear. or painless performance or tci makes your converter lockup work in 4th gear only by plugging in the plug and locking up through vacuum.
You need one of these, if you don't already have it.
http://www.painlessperformance.com/w...rchField=60109
1990 Chevrolet RCSB●LS1/4L60E Scrimpin Ain't Easy
BAD BOW-Silverado XST
Everything you need know for a 700R4 conversion from a 350th.
http://transmissioncenter.net/700R4_Swap_Info.htm |
GoatLube Experss
![]() Join Date: Oct 2009
the small 4 pin connector on the driver's side is for tourqe converter lock up, if it has another plug on the other side it is a computer controll'd 700R4E . I ran a 700R4 in my V8 s10 with out the TC lock up hook'd up for 4 or 5 years with no problem's . with a little research you can find how to hook it up with out buy'n an expensive kit . one thing to remember ir that the 700R4 is as long as a "long" tail shaft T350 which I believe is what your truck has .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#7 | |
The Crazy Machanic
as for the lock up was thinking of using this http://www.bowtieoverdrives.com/cata...php?ITEMID=332 And it seems i don't need the steering column? from a 700r4 truck thought that would throw things off guess not as for drive shaft got one coming from where the trans came from thanks looks as if i might have this figured out (i hope) thanks for the help also the trans is a 1991 trans
The stock driveshaft presently in your truck will work perfect I did swap on my 86 with TH350c and driveshaft was right length.
