Old 02-14-2010, 11:47 PM   #1
eosrider
First post! Lets start with carbs lol
Hi guys! i'm Laurence.
Just made a purchase of a 67 GMC long bed
shes got a 350 with a edel 1405 under the hood.
wanting to start off by making sure my mixture is good as can be for balanced power and fuel econ.
anyone?
eosrider is offline   Reply With Quote
Old 02-15-2010, 12:23 AM   #2
1970rs
1970rs's Avatar
Re: First post! Lets start with carbs lol
First, you need to adjust your idle mixture screws. Make sure the engine is warm and in nuetral. Hook up a vacuum gauge to it. Now adjust each screw an 1/8 turn at a time to obtain the highest vacuum reading. Make sure you keep the screws even.
As for jetting it is best to read your plugs to determine if you need to change the jets or not.
1970rs is offline   Reply With Quote
Old 02-15-2010, 09:05 PM   #3
LEEVON
LEEVON's Avatar
Timing first! Initial and total timing need to be set along with a proper curve if you can. Make sure there are no vacuum leaks by spraying around the carb base with some carb cleaner while it is running.
Then what he said plus you should back off 1/8 turn from the highest vacuum reading. After that you can play with the metering rods and jets but you probably won't need to.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 02-15-2010, 09:21 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
I would add, lightly screw in the mixture screws until they seat. Unscrew them out 1 1/2 turns. Then proceed with setting the exact mixture. You'll probably end up turning the screws in some to get highest vacuum.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-16-2010, 01:06 AM   #5
70cst
70cst's Avatar
By the way: and from Ohio. Glad to have you as part of our internet truck family.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-16-2010, 05:50 PM   #6
eosrider
when you say until they seat. do you meen screw them all the way down then back them out?
Old 02-16-2010, 06:18 PM   #7
Sinister
Between Trucks...
Sinister's Avatar
Yes, screw them in all the way, but easy does it, lightly seat them. Then back them out 1 1/2 turns. That way you'll know there adjusted the same on each side.
Beat it to fit,
Old 02-16-2010, 07:47 PM   #8
eosrider
houston we have a problem
my 350 sounds like a diesel engine.
dwell tach says its idling 500-600 rpm
timing light is now broken (just as i need to use it!!! lol )
oil pressure gauge is not working (was yesterday)
oil is at full line.
im sure this is just a coincidence.
Old 02-16-2010, 08:03 PM   #9
Sinister
Between Trucks...
Sinister's Avatar
Pickup might have fallen off the oil pump. Weird for an oil pressure gauge to quit like that.
Beat it to fit,
Old 02-18-2010, 12:29 AM   #10
eosrider
is there another way besides taking off the pan to find out? im doubting it.
it sounds like my crank and pistons are not knocking but my valves are chattering like a mofo.
Old 02-18-2010, 09:00 AM   #11
Sinister
Between Trucks...
Sinister's Avatar
You'll have to drop the pan to check. If your valves are making a bunch of noise, it sounds like no oil pressure. I wouldn't run the motor until you figure out what's up with it.
Beat it to fit,
