Old 02-15-2010, 12:39 PM   #1
Papaloo
Papaloo's Avatar
Side Saddle tanks on 71 lwb
I am looking to relocate my in cab tank for more space behind the seat, but I don't want to use a behind the axle tank and lose my spare tire. Does anyone know if the 73-81 or 82-86 side saddle tanks will fit on a 71 lwb?
I'm not worried about the side impacts since I don't plan on mounting model rocket engines on my fuel tank like Dateline did.
Papaloo is offline   Reply With Quote
Old 02-15-2010, 01:52 PM   #2
mrein3
mrein3's Avatar
Re: Side Saddle tanks on 71 lwb
Unless the later year models fit without too difficult of a mod, I would look hard for the 67-72 aftermarket saddle tanks. LOTS of people have trucks with them and thanks to the NBC fabricated controversy, lots of people are afraid of them. Folks usually give them away.
Note they usually don't come with a float to tell you the level in them. I have one saddle on my truck and used a gauge/float kit from JC Whitney.
If you find a set-up make sure you grab the 3-way valve that is usually mounted to the left of the driver on the floor.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 02-17-2010, 05:37 PM   #3
68 TT
Still plays with trucks
68 TT's Avatar
Good question. My 67 C-10 has the in-cab tank only now but someone in the past had installed dual side saddle tanks with filler doors in the bed sides but they had been removed before I got the truck. It does still have the three way valve on the floor at least.
I will take some measurements of the tanks on my 78 and see if they can be made to fit. They have the same frame rail spacing so I don't see why not.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-17-2010, 06:27 PM   #4
hicktownhotrodder
Rollin Coal
hicktownhotrodder's Avatar
the 73-87 tanks are alot longer. i have also looked into it. you would have to cut out part of the cab corner to make it work. but i dont see why that would be an issue
I have three letters to all these import guys:
God-Made-Chevy
04 GMC Sierra 2500HD Duramax
1972 Chevrolet C-30 Dually Pickup stock? 350 SM465 four speed
1977 GMC K-35, TH-400, 4X4 450 horse 454(dad's)
1993 Dodge cummins 5-speed DEAD!!
hicktownhotrodder is offline   Reply With Quote
Old 02-17-2010, 06:33 PM   #5
Papaloo
Papaloo's Avatar
Maybe since I have a LWB, if I get the side saddle tanks for the SWB 73-87, They'll fit without cutting the cab?
Thank you for the responses so far. This has been helpful.
Old 02-17-2010, 06:44 PM   #6
68 TT
68 TT's Avatar
The 73-87 short bed 16 gallon tank is 42 7/8" x 14 1/8" x 11".
The long bed 20 gallon version is 56" x 14" x 11".
