Old 02-15-2010, 02:31 PM   #1
budman k20
1972 K20
Question Tilt steering rebuild available parts
Help,
I'm getting ready to re-assemble my truck and I noticed that my tilt steering column has a worn out shift pin hole for the shift lever. What are my options? Does someone make a new collar? I have thought of using adhesive or drilling larger and bushing it. I'm guessing this is a common wear item. What have others done? Anyone else fix this problem with success?
budman k20 is offline   Reply With Quote
Old 02-15-2010, 08:42 PM   #2
JimKshortstep4x4
Re: Tilt steering rebuild available parts
It is a common problem and the part is not reproduced. I had some oversize pins made which worked for a small amount of wear. Bushings are always an option. The other thing you might try is to find someone that is modifying a tilt for a floor shift. You might be able to work out some kind of trade since the shift boss is removed when modifying a column to use it as a floor shift tilt.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-16-2010, 01:17 PM   #3
jaros44sr
jaros44sr's Avatar
Originally Posted by budman k20 View Post
Help,
I'm getting ready to cut off that bump for the lever, mine is tight. I want to smooth out my bowl. If you want to trade parts lmk
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-16-2010, 01:41 PM   #4
budman k20
1972 K20
That would be awesome! The one I have is fine other than the pin hole being oversize. Let me know how you want to do the swap and I will make it happen.
Old 02-16-2010, 02:04 PM   #5
71swb4x4
71swb4x4's Avatar
CPP has a whole rebuilt column for sale. I would call them and see if they do sell just the bowl.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-17-2010, 02:08 AM   #6
jaros44sr
jaros44sr's Avatar
Is yours apart? Got pictures of it, so I can compare it to mine. Just want to make sure we are trading the same piece...PM me, cause I almost missed this post
If it is not apart, you will have to totally disassemble, as the bowl is the first part to get reassembled
It's the one on the right
SAFETY FIRST
AS usual, off topic
Jim
Old 02-17-2010, 04:39 PM   #7
jaros44sr
jaros44sr's Avatar
Depending on how big the hole is, you could close it up by dimpling it with a center punch all the way around the holes, and then some sort of adhesive to help keep it in place... lab metal is pretty neat stuff
SAFETY FIRST
AS usual, off topic
Jim
Old 02-17-2010, 04:46 PM   #8
budman k20
1972 K20
I was thinking I could use liquid metal or something like that to fill the gap. I was hoping someone had already figured out the best way to fix it. Trading parts may be more of a hassle than its worth for both of us! But thanks for the offer.
Bud
Old 02-17-2010, 05:31 PM   #9
msgross
msgross's Avatar
Already smoothed mine off or i'd trade ya...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-17-2010, 07:07 PM   #10
jaros44sr
jaros44sr's Avatar
Bud
No problem, but I agree, since yours isn't apart, it would be a hassle for you. OK, now I'm going to shave mine
SAFETY FIRST
AS usual, off topic
Jim
Old 02-18-2010, 12:16 AM   #11
dmec
dmec's Avatar
how about filling the hole with jb weld and redrilling hole to fit?
dmec is offline   Reply With Quote
Old 02-18-2010, 12:36 AM   #12
70LonghornCST
Moderator
70LonghornCST's Avatar
I saw this industrial strength soder type material at the local swapmeet a year or two ago. It was VERY strong and easy to apply (welding ligther). Does anyone know what that product might be called? I guarantee it's stronger than JB Weld.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
