Old 01-31-2003, 12:33 PM   #1
Eagle1
Dual or Single Exhaust?
I have a recently rebuild 307 engine and im thinking about doing the exhaust. Which would be better a 2” dual exhaust with dynomax super turbos, or a single 2 ¼-½" with one super turbo.
Thanks Eagle
77 C10 truck 355/TH350, 10:1 KB's, COMP XE256H, EDELBROCK PERFORMER, CARTER 600 CARB.
Eagle1 is offline   Reply With Quote
Old 01-31-2003, 12:43 PM   #2
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Duals!!!
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 01-31-2003, 12:45 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
How loud do you want it to be? The dual exhaust would be a bit quieter because it has 2 mufflers, while the single would have one. I would be tempted to get a single 2.5" pipe, and a Dynomax Hemi Turbo muffler, which is like a quiter Super Turbo. Power will be about the same for either system.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 01-31-2003, 12:53 PM   #4
barn9
Half a bubble off!
barn9's Avatar
Nothin' sounds better than a nice set of duals. Single exhaust is for granny's car.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 01-31-2003, 02:10 PM   #5
MU72
MU72's Avatar
barn's right, single exhaust is for nancy boys. Go for the duals. You might want to look in to a set of glasspacks. Lots of people don't like the sound. Personally, I don't think you can beat that sound on these old trucks. There are many different option you can go with in the packs. I used to have a set of 24" packs on my truck. Not too loud just a nice rumble but talked when you put you foot in it. Best of all, they are cheap.
72 Cheyenne 1/2T LWB
original ochre/white
09 Silverado ECSB
76 International ScoutII
MU72 is offline   Reply With Quote
Old 01-31-2003, 02:28 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
As much as I like a set of chrome tips hanging out from under the bumper, a single pipe is cheaper, and performace wise, your 307 (I asume stock) is not a fire breather and little gains would be seen with a set of pipes verses a good single set up.
Onless you are planning on a larger engine in the future, and if you are trying to watch the out going cash flow, (or the wife is watching that for you) I think i would go with a single pipe system.
Old 01-31-2003, 02:38 PM   #7
JimKshortstep4x4
Talking
Duals will give you less restrictive exhaust, even with one 2 1/2" exhaust.
Cross sectional area of a 2 1/2 " pipe is 4.9 square inches.
With 2" duals, the area is 6.3 square inches.
Jim
Old 01-31-2003, 02:41 PM   #8
crazy longhorn
Fabricate till you "puke"
I am a fan of duals! I ran 2" pipe , with H pipe , superturbos, & side exit tail pipes(behind the wheels) on a 305 powered flatbed. The system sounded nice......not too loud, but you could hear it. the H pipe in the system will mellow the note & give a more "tuned" sound......also helps with the low & midrange tork. good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-31-2003, 02:50 PM   #9
Longhorn Man
JimKshortstep4x4 is right, however, you can go too far with pipe size. It is not as dramatic as picking a huge tube header, but too much pipe Cross sectional area will kil your lower end torque...which is all a 307 has going for it.
Old 01-31-2003, 02:54 PM   #10
crazy longhorn
2" pipe should be fine on the 307......I wouldnt go any bigger tho........crazyL
Old 01-31-2003, 03:09 PM   #11
3damnboyz
3damnboyz's Avatar
twice pipes!
72 short wide
55 stepside- 2nd generation
"come on honey, we need more old trucks to fix up for the boys to drive, they will be driving before ya know it!"
3damnboyz is offline   Reply With Quote
Old 01-31-2003, 03:20 PM   #12
gman
Don't mean to steal your post eagle.....
Would 2 inch duals with the "H" pipe be the way to go for a 72 4X4 also? No headers yet........not sure about them. Can you add headers later to a setup like this if you choose to do so? Suggestions? Stock 350.......will be rebuilt soon with a bit more goodies in it but no race car intentions.
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air
2000 Harley...Wide Glide
gman is offline   Reply With Quote
Old 01-31-2003, 03:31 PM   #13
crazy longhorn
gman, the 4x4s take a little more power to turn everything......I would run 2" on a pretty mild 350. If it was a 2wd, I would think about going 2 1/4" on the pipe. As far as the headers, due to the "fun way" the 4x4 pipes lace in, i would install them before the exhaust was done to save on headaches later. crazyL
Old 01-31-2003, 04:04 PM   #14
gangforward
Hootis is as Hootis does...
gangforward's Avatar
2 pipes. 2 cool.
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires
1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires
1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires
gangforward is offline   Reply With Quote
Old 01-31-2003, 04:22 PM   #15
barn9
Half a bubble off!
barn9's Avatar
I had duals (with an H pipe) on another truck that had a 307 in it, and I never regretted it one bit. I had the duals with H on my current truck before I changed to headers, and the change was no problem. Anyone that knows his stuff can mate them up with no problem. And I also feel very strongly that any dual system should have either the H or an X pipe. I also like glasspacks, love the sweet sound of dual glasspacks rumbling! Single exhaust is just plain LAME !
Just call me LB.
Old 01-31-2003, 04:38 PM   #16
crazy longhorn
I have mated headers to an existing system, but just as an observation(from working in an exhaust shop)....once upon a time! The systems are much cleaner looking, & will have a couple less splices in them if all the work is fitted/ done at the same time.....crazyL
Old 01-31-2003, 06:12 PM   #17
Eagle1
Thanks Guys for the replys the reason I was asking was the exhaust is going on my sisters car, its a 69 chevelle malibu right now it has a 2.25" single exhuast with a stock muffler and catalytic converter someone put on, before we bough the car. She does not want to be loud. But price wise how much would a complete 2" dual exhaust be with two dynomax super turbos vs.
a single 2.5" exhaust with one dynomax super turbo. The whole exhaust needs to be done from the exhuast manifolds to the muffler(s).
Thanks Eagle
Old 01-31-2003, 06:20 PM   #18
crazy longhorn
Price would depend on the area & how much competition there is in exhaust work. In my area, I would say in the range of $250-300 on the duals, & the single exhaust might be $75 cheaper. good luck, crazyL
Old 02-01-2003, 03:06 AM   #19
cheyenne10
cheyenne10's Avatar
tranny interference
Does anyone try to route exhaust and H pipe so the tranny and transfer case if so equiped can be removed without butchering exhaust? Any tricks?
Bob
cheyenne10 is offline   Reply With Quote
Old 02-01-2003, 12:49 PM   #20
jhwkns
Registered Cruiser
jhwkns's Avatar
If you put a coupler (flange) on the crossover pipe the exhaust can be easily dropped out of the way.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 02-01-2003, 01:48 PM   #21
71-longbed
Its Magically Delicious
71-longbed's Avatar
get duals .....straight out the back .....
71-longbed is offline   Reply With Quote
Old 02-01-2003, 03:14 PM   #22
71k5
I think I'll try a single 3" sustem with a 3" flowmaster when I get my big block in; out the side behind the rear wheel because I tow so much.
71k5 is offline   Reply With Quote
