Old 02-15-2010, 04:41 PM   #1
RIDDLA
RIDDLA's Avatar
Need you'r thoughts
I bought a 89 gmc Suburban 5,7 700r4 4x4. The problem is my oil pressure it seems low it moves to 15 then will drop to 0 step on the gas and it picks up pressure to 30.Is this normalfor the trucks? I changed the oil filter and oil to 10w30 chevron with ac delco filter. while down there i noticed it has a oil cooler is this factory or did the po install
68 GMC-Stripshow
70 Chevy Monte Carlo
72 Chevy Monte Carlo LOLO
72 Chevy Suburban Blurban
74 Vw Bug
78 Chevy k10 lwb
78 Chevy k10 swb
03 Cadillac Escalade-Duecesix
84 Cadillac Coupe Deville DeElegance
B.O. A Lifestyle Money Cant Buy!
Win,Lose, or Tie
I'm a Raider till i die
RIDDLA is offline   Reply With Quote
Old 02-25-2010, 10:52 PM   #2
muddyblazer02
muddyblazer02's Avatar
Re: Need you'r thoughts
check the oil pressure sender and the connection if it is good then see if you really have oil pressure. put a mechanical gage on it. you may be able to get a loaner from the parts store. if you have oil pressure then try changing the sender. if not start looking thinking oil pump or you have worn bearing on the main bearings.
ken
truck junkie
muddyblazer02 is offline   Reply With Quote
Old 02-26-2010, 01:29 AM   #3
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Is it possible that you are not putting enough oil in it? With the oil cooler, it will need more oil than normal.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 02-26-2010, 10:40 PM   #4
muddyblazer02
if it is showing full on the dipstick then its full cooler or no cooler because the cooler would hold oil in it. we know it has oil in it because the truck is running. however if the cooler has a leak then that could affect oil pressure.
ken
truck junkie
Old 02-27-2010, 01:49 AM   #5
Driveway Dreams
I have car A.D.D.
Of course it is full if the dipstick shows full, but this has not been stated yet. Also, it could still be running well even if a little low on oil. I am only trying to point out something that may not have been thought of, to help diagnose the issue.
-Gerald
Old 02-27-2010, 07:05 PM   #6
low88burb
does it have alot of miles on it ? when the crank and rod and main bearings have alot of wear your oil pressure will drop and pick up with rpm .
low88burb is offline   Reply With Quote
Old 02-28-2010, 12:50 AM   #7
RIDDLA
RIDDLA's Avatar
I did find a leak it has 128000 miles
68 GMC-Stripshow
74 Vw Bug
78 Chevy k10 lwb
78 Chevy k10 swb
Win,Lose, or Tie
Old 02-28-2010, 05:16 PM   #8
Tony_SS
Tony_SS's Avatar
Start with changing the sender.. see if that helps.
Tony_SS is offline   Reply With Quote
