Old 02-15-2010, 07:52 PM   #1
quentin hill
quentin hill's Avatar
transmission cooler
I just purchased a 72 C-10 stepside. I am currently taking it apart getting it ready for some new paint and checking everything out to make sure it is road worthy when complete. It has a transmission cooler strapped to the radiator. If I am just planning to drive this around town do I really need the transmission cooler or can I put the line back to the radiator like it was originally.
Thanks for your time
quentin hill is offline   Reply With Quote
Old 02-15-2010, 08:17 PM   #2
aintmisbehavinn
Re: transmission cooler
Trans coolers will only make your trans last longer, yes keep it if you can. These trucks are not exactly light, pulling all the weight will keep things cool.
aintmisbehavinn is offline   Reply With Quote
Old 02-15-2010, 11:17 PM   #3
flashed
Sorry about hijacking this thread but where can you get the plastic things that holds the trans cooler to the radiator ? Mine has the cooler run thru the radiator but just hangs out front with zip ties.
flashed is offline   Reply With Quote
Old 02-16-2010, 11:37 AM   #4
quentin hill
Thanks aintmisbehavinn I use to live in Lawrenceville still have friends there.
Old 02-16-2010, 11:53 AM   #5
big_al_71
big_al_71's Avatar
I would definetly reccomend to keep a tranny cooler in there, at least for me being in miami it is a must....here is a pict of how I mounted mine to give you an idea.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 02-16-2010, 12:00 PM   #6
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Talking Re: transmission cooler
Straps for cooler mounting Napa # 1-4829
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 02-16-2010, 12:01 PM   #7
jsbgump
Gone Fishing
jsbgump's Avatar
You should be able to get the mounting kit at your local parts store
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 02-16-2010, 01:44 PM   #8
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Summit carries several types. I use them on my electric fans. If you can't find what you want, PM me as I have a few kits in the garage and I will send one to you.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
