Old 02-15-2010, 07:59 PM   #1
nplocoman
never finish start another
nplocoman's Avatar
Spark plugs
I am changing a 69 with a 307 standard distributor to an hei. what number of plugs are you using? Or maybe a year range and I am guessing a 350 plug. What works best? Heck should I just widen the gape on the ones I have and run them?
nplocoman is offline   Reply With Quote
Old 02-15-2010, 08:34 PM   #2
JimKshortstep4x4
Re: Spark plugs
I run my plugs at .045 when used with HEI ignition but .035 works also!
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-15-2010, 08:34 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Re: Spark plugs
You can run whatever plugs you normally run. Just gap them to .040-.045
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-15-2010, 09:50 PM   #4
nplocoman
nplocoman's Avatar
Re: Spark plugs
Great! thanks! Finnaly somthing I don't haft to buy new!
Old 02-15-2010, 10:01 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Spark plugs
Eight
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 02-16-2010, 01:29 AM   #6
69heavychevy
69heavychevy's Avatar
Re: Spark plugs
i run ngk's gapped at .045
69heavychevy is offline   Reply With Quote
Old 02-16-2010, 01:36 AM   #7
67ss&99ss
Andy
Re: Spark plugs
agreed. I have tried AC, Champion, Autolite and NGK. I have had the best results with NGK. Now I run them in everything.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi
1969 CST/10 383|Aisin AR5 5 speed
1972 K5 350|Turbo 350 4x4
2005 Duramax 2500HD 4x4
67ss&99ss is offline   Reply With Quote
Old 02-16-2010, 12:08 PM   #8
ole red
Re: Spark plugs
I still run the AC and gap them at 45
69 stepside, 1/2ton, 4X4, 350/350/205
ole red is offline   Reply With Quote
Old 02-20-2010, 05:37 PM   #9
keenan
keenan's Avatar
Re: Spark plugs
AC delcos are industry standard for gm engines.
champions are for chryslers.
bosch for ford.
keenan is offline   Reply With Quote
Old 02-20-2010, 06:51 PM   #10
gonzo6869
Cops, ha, catch me if you can!
gonzo6869's Avatar
Re: Spark plugs
I agree with all of the above, I have HEI AC Delco gapped at .045
72 C-10 Stepper
350/TH350
3.73 in the back
Edelbrock intake and Carb
Hooker Comp Headers
275/60R15 on Rallies
gonzo6869 is offline   Reply With Quote
Old 02-20-2010, 07:17 PM   #11
evilways
evilways's Avatar
Re: Spark plugs
Don’t some spark plugs have a ‘T’ at the end of the part number for using larger gaps?
Mark
1967 C/10 stepside lwb daily driver
1968 C/10 fleetside lwb parts truck
1971 Cheyenne Super swb project
evilways is offline   Reply With Quote
Old 02-20-2010, 07:28 PM   #12
neba
Re: Spark plugs
andy, you say you have the best results with NGK. what does that mean? runs better, gas mileage ??? i have heard if you run 44TS you would use 44TSX with an HEI dist. AC DELCO is designed for GM, that is what i use.
neba is offline   Reply With Quote
Old 02-20-2010, 07:34 PM   #13
CB24
Re: Spark plugs
Has anyone run the e3 plugs? Just curious if they're a gimmick or they actually perform well.
CB24 is offline   Reply With Quote
Old 02-20-2010, 07:54 PM   #14
hchad18
hchad18's Avatar
Re: Spark plugs
Wish I could remember where I seen it but I've heard they actually out perform post plugs on the market, and they are the real deal. I think I might have seen a test on horsepower TV.
http://powerblocktv.com/blog/?p=146
hchad18 is offline   Reply With Quote
Old 02-20-2010, 08:49 PM   #15
nplocoman
nplocoman's Avatar
Re: Spark plugs
Originally Posted by Stocker View Post
Eight
So My new 7 hole distrubuter won't work. I have been ebayed again!
Old 02-21-2010, 01:54 AM   #16
69heavychevy
Re: Spark plugs
bosch for ford.
actually motorcraft would be for fords, and bosch for german cars
Old 02-21-2010, 02:28 AM   #17
Trip59
Who needs sleep...
Trip59's Avatar
Re: Spark plugs
Give it to a ford guy... tell them it's the newest fuel efficiency design and double the price.
I don't want to hijack, but I had a question that dovetailed with the original question. I was handed an HEI that came out of a 73 with a 307... yeah, not original... BUT my question is, the PO had installed anti-fouls How do those play in with gapping an HEI fired plugfor a 307?
Trip
Trip59 is offline   Reply With Quote
