Chevy Lover Till The End.
Got a question. How low can I go using springs and drop shocks without having to use shock relocators? I just bought 3" lowering springs and shocks for the front and 4" lowering springs and shocks for the rear with a new Trac Bar in a kit from TruckandCarshop. The P/O heated all four springs on my 69' so I don't know how low it is now but I do know it has factory shocks on it and the left rear shock is real weak if not blown. If I can use this kit without shock relocator's it would be great but if I have to use them then I will put my buddies on hold and order them. I will do whatever ya'll recommend.Here is the stance of my truck now with 275/75/15 rear and 255/70/15 front. Also, it has a BBC in it.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 Last edited by Camaro_nut2001; 02-15-2010 at 09:58 PM. Reason: Forgot to add engine size, sorry. |
![]() Join Date: Apr 2005
Re: When to add shock relocators?
I would recommend installing them while you're doing spring install. You're right on the border of needing them right now and you know you're going to want to go lower eventually,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
You're right, I do plan on going lower maybe next winter. I am just trying to get it ready for the Rod Runs this year and the first one is in April. Do you think I should just put the new drop shocks on now to fix my weak or blown shock and do the springs with shock relocator's next winter? I am kinda pressed for money and time as I want to get my seat and dash done before April, lol. Thank you for your advise.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
![]() Join Date: Jan 2007
I have heard that 4" drop and lower in the rear = shock relocators [to keep ride quality the same]...but then you are also talking lowered shocks, adjustable panhard bar, etc.
Brakes & Suspension = Safety. Do them first, fix your interior later,
Something else to consider.... Lowering blocks will give you drop w/o affecting shock travel. In stead of 4-5" springs, use 3" springs & a lowering block (CPP sells them or if you're on a budget, you can make your own).
To determine whether there's a need for relocating the shock mounting points, all you need is a tape measure. Measure the distance between the upper & lower mounting points @ ride height & compare them to the shocks measurements (you need to know the fully compressed/extended lengths). Estimate 2-3" travel for compression & extension of the suspension as it cycles through it's range of travel driving down the road. Do the basic math (subtract the 2.5" travel range from the shocks length @ ride height; add 2.5" to the shocks length @ ride height) to determine if the mounting points need to be tweaked or if different length shocks are needed. Some useful info.... http://67-72chevytrucks.com/vboard/s...owering+blocks http://67-72chevytrucks.com/vboard/s...ock+relocators
Thank ya'll very much. This forum has some of the nicest people on earth. I will use everyone's advise and I know it will work. Hot Rod you spoke the truth but how did you know I was also doing my brakes, lol? I am going to do some measuring and then measure some more and I will tell you this- If I am riding on seat springs instead of new foam and leather at the spring rod runs ya'll better not laugh cause you know I am being safe, lol. Just kiddin, really, thanks a bunch for the help.
I forgot the rears....
http://67-72chevytrucks.com/vboard/s...d.php?t=359399
#9 | |
![]() Join Date: Feb 2001
I agree...I lowered the Circuit Rider 2"/4" and added shock relocators plus the panhard bar...you'll be glad you did!
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#10 | |
the more vertical the shocks are the better they work
ENGINE BUILDER
The rear shocks go from vertical to horizontal as you go lower and become ineffective. You really need to install them in the rear.
JIM ZAG |
#13 |
Restoration Virgin!
good info here....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#14 |
![]() Join Date: Oct 2001
From what I've read on the ECE suspenion stuff, anything after 4" needs the shock relocator kit! 5" or more would require this.
Hope this helps. I got 4" drop springs and belltech drop shocks and a adjustable pan hard bar!
Things happen for a reason! |
#15 |
I am a Referee of life.
Throw a couple of cheap Indian Blankets on that seat and fix the mechanicals'It's no fun to sit one out on a new seat.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#16 |
Welcome to my world...when I first lowered my thruck all I thought I had to do was change the coils...wrong.
#17 |
LOL, you got that right and that's what I intend to do.
