Old 02-16-2010, 12:14 AM   #1
bobber80
layin frame what driveline
Im having a custom made triangulated 4 link with air ride put in my 62 chevy swb when done it should allmost lay frame will the stock two pice driveline pivot enough to lay out or will I need to put in a one pice ......
Any info would help alot
bobber80 is offline   Reply With Quote
Old 02-16-2010, 04:04 PM   #2
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Re: layin frame what driveline
Most bagged guys prefer the two piece shaft over the one piece. It will have enough movement and will allow you to do less cutting on your cab floor.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 02-17-2010, 02:39 PM   #3
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
I like the stock 2 piece. It allows more than enough travel but the angle is steep to the pinion. Adapt the 63-72 2 piece and it works better because the rear half is longer.
Imperial Kustom LLC
Meridian Idaho.
I never stopped playing with cars, they just got bigger.
Imperial Kustom is offline   Reply With Quote
