Old 02-16-2010, 12:56 AM   #1
salrod00
salrod00's Avatar
truck wont turn over
oh right guys i know we all heard or been through this but i went into my 84 stepside and know it wont start. i put the key forward, dash lights come on and go to crank it and no noise or clicking or anything happens. what could be the problem. i had put a battery and turn on perfectly and today nothing. tried jump start it and nothing. what yall think could went out. or how can i manually start it with out the key.
salrod00 is offline   Reply With Quote
Old 02-16-2010, 01:01 AM   #2
raws67
raws67's Avatar
Re: truck wont turn over
Auto or stick? If its an auto it might be the neutral start switch. Try pulling your gear selector to the left when turning the key on.
raws67 is offline   Reply With Quote
Old 02-16-2010, 01:18 AM   #3
54Caddy
GM Addicted
54Caddy's Avatar
maybe your collum has messed up like mine, take the panels off the bottom and loosen the ignition switch try pulling it towards you and maybe itll start, if anything just to get it on the road you can wire up a toggle switch to the starter on wire to the battery on the posative and the other wire to the s terminal(the small one on starter) youd be able to turn the power on with the key then hit the toggle to start it and youll be fine but id check out the ignition switch for sure, could be the rod in the collum has messed up sounds like the same exact problem i just had with mine good luck man.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 02-16-2010, 02:09 AM   #4
salrod00
salrod00's Avatar
its auto column. where is the neutral switch exactly. and the ignition switch on the column seems fine i pull the rod and push it but no response to turn on . i might take it off and buy a new one just to be on the safe side. there are pretty cheap anyways. thanks for the info. i keep trying to figure it out.
Old 02-16-2010, 02:55 AM   #5
spinem
haha, ford guys...
do u have a volt meter? test the purple wire on the starter while some one is trying to start it (be safe, very dangerous)
also test the positive lead to the starter, if neither, prob a netural saftey switch or maybe starter.
spinem is offline   Reply With Quote
Old 02-16-2010, 09:45 AM   #6
Jonboy
Slots go on anything!
The neutral safety switch is the one at teh bottom of teh column, right by the firewall. Check the connections to make sure that they are on. If so, you may need to adjust the switch.
1974 Jimmy- 5.3/4L80e/NP241
Old 02-16-2010, 01:46 PM   #7
McMurray76
Like Spinm said start checking voltage before you start throwing money at it. Check the battery also. Just because it is new doesn't mean that it is good. Check the voltage at the batt with everything turned off, then keep your eye one the meter while someone turns the key to "start".
McMurray76 is offline   Reply With Quote
Old 02-16-2010, 08:23 PM   #8
salrod00
salrod00's Avatar
well its not the battery. i even put my tahoe battery on it and no response. and the neutral switch at the bottom seems fine . but i havent tried to by pass it. i bought the ignition switch on the column for 10 bucks so hopefully that will be it. if not next thing will be trying to run a switch to the starter to start it . last time i had it running it turned over fine. ran for 5 minutes until i killed it. now im surprised about it. maybe something small. thanks for the suggestions.
Old 02-16-2010, 11:44 PM   #9
spinem
haha, ford guys...
words of a wise man.
Old 02-17-2010, 01:18 AM   #10
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Pull your starter and have it bench tested at your local auto parts store i.e. NAPA, CARQUEST, O'RILEY'S......
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 02-17-2010, 10:06 PM   #11
datguysaL
yup, check your starter, could of gone bad,
or like my old 85 chevy, oil seeped into the starter bolts and they came loose over time, and gears got stuck (jammed) with the flywheel. and did the same thing, wouldnt click, or anything.
datguysaL is offline   Reply With Quote
Old 02-17-2010, 11:39 PM   #12
Fastest32
Fastest32's Avatar
Check the fusible links at the starter and alternator
Fastest32 is offline   Reply With Quote
Old 02-18-2010, 12:05 AM   #13
82chevy350
82chevy350's Avatar
try jumping the starter with a screw driver see if that works
Drive It Like Ya Stole It
'82 Primer White c10 2wd LWB 350 sbc t350
(Hot Rod)
'90 2wd LWB Silverado 350 tbi 700R4
(Daily Driver)
'53 m38a1 Willys Jeep
(Toy)
82chevy350 is offline   Reply With Quote
Old 02-18-2010, 02:39 AM   #14
westofb
I really hate wet sanding!
westofb's Avatar
that is where i would start too, leave the key off, jump the two terminals it should crank, but won't start with the key off. if it won't crank, starter is shot.
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 02-18-2010, 03:36 AM   #15
spinem
haha, ford guys...
don't go turning bolts before testing it yourself like i mentioned before.
dont jump it incase there is a bad ground or something and it fry's your computer controlled yukon and costs you more than the entire truck is worth.
