Old 01-31-2003, 02:17 PM   #1
jays68yak
jays68yak's Avatar
Will the stock tach work with HEI??
So will it? Mine was converted to HEI before I bought it. The tach was unpluged from the cap. I pluged it in and it will hardly move. Has my tach gone bad? Could it be a bad ground? Or something else???
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 01-31-2003, 02:41 PM   #2
JimKshortstep4x4
Talking
Stock tachs will definately work with the HEI distributors. Something must be wrong with your tach.
Jim
Old 01-31-2003, 03:48 PM   #3
ckhd
ckhd's Avatar
I agree that it should work.
On that note, the guy I bought my '72 K10 'burb from said that he had tried to convert it to HEI, but the tach wouldn't work,so he put it back.
All i can say is make sure that your connections are tight, and you are on the 'tach' terminal of the distributor...
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 01-31-2003, 05:03 PM   #4
70cst
70cst's Avatar
Pertorinx HEI
I've got a Pertronix HEI and my factory woks as good as the old way.
70cst is offline   Reply With Quote
Old 01-31-2003, 06:00 PM   #5
billogna
billogna's Avatar
I've got the original tach with '76 original (Autozone) HEI, works great, "tach" terminal is labled on distributer.
'69 Chev Cust/10 swb, 350/700R4, 5"/6"
'70 Chev C10 swb, 67 front, 454/700r4, 4"/5"
'73 Chev stepper, 350/3 spd
'84 Chev K20 350/4 spd
'91 GMC 1500 Suburban 4x4, 350/700R4
billogna is offline   Reply With Quote
Old 01-31-2003, 07:52 PM   #6
StingRay
StingRay's Avatar
Been running one that way for years with no problems.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 01-31-2003, 08:13 PM   #7
Andy4639
Old member
Andy4639's Avatar
Cool Tach/ HEI
There are quite a few things it could be.
1. Could be a bad ground.
2. The terminal in the HEI is not hooked right. (inside the coil)
3. The tach itself needs adjusting.
4. Tach could be broke(wires crossed on tach)
5. Connector is bad on distrbutor
You wouldn't believe the stuff I found on mine when I bought it. People do some of the darndest things.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
