02-16-2010, 06:27 PM | #1 |
Have Projects , need answers.
Hi, just joined and I have several motorhomes,trucks and vans for parts and want to make something out of them. Any comments or problems I might encounter, please help.
1) 1978 original K-30, 350, compound low trans, 205 transfer, 4:11 gears, manual hubs with totally rusted Custom Deluxe body, runs great. 2) 1985 C-10 Silverado LWB, no engine or trans(was 350ci/AT). Good straight rust-free body, Blk on Blk. 3) (3) 454BB/AT combo's removed from 3 motorhomes, all running. Are the rear ends good for anything or just scrap? 4) 1997 Suburban 350/AT with front end damage, needs only clip with core support, etc. all else is fine, one owner, dual A/C, leather, etc, loaded. 5) 1985 GMC 2500 Vandura cargo van, bad rear end, rough body, great running 350/AT. My first thought was to replace the '78 body with the '85 body only wanting to keep the manual trans parts, pedals, etc. and install one of my 454BB in the drive train. Will the cab and bed bolt right up? Will I have most all of the parts on hand to do this? I know I should use new motor mounts, etc. But will most all of this fit? My other crazy thought was to put the 'Burb on the 1 Ton gear with a BB/AT or Manual? See many problems with this? The 2500 van is just going to be a work truck, but needs a rear end(gears all gone and carrier too) I have a 1994 Chevy C20 complete rear in located from a friend for $100, will it just bolt in? They are both 5 lug axles. Any and all suggestions will be appreciated! Thanks, Rick |
02-16-2010, 06:43 PM | #2 |
Re: Have Projects , need answers.
Your 78/85 swap is a good idea. You'll need to reuse the tranny hump from the 78 (unbolts) to put in the 85 cab. The auto tranny humps are smaller.
02-16-2010, 07:40 PM | #3 |
sell it and buy what you want,sounds like way too much work for me
02-16-2010, 10:12 PM | #4 |
The One And Only !!!
Think I'd be lost with all that sitting in my yard too !
The 78/85 body swap sounds like a winner, Sell some of the other stuff and pick up a front clip for the burb and the rear end for the 2500 Van. The end results would be a nice 4x4 for on/off road and towing, The burb for luxury freeway flyin and the 2500 for work.... BTW, Welcome Aboard from another Floridian !!!
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
