Old 02-16-2010, 07:08 PM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
Question Compressor Mounting Question??
okay, the mechanical engineer in me is scratching my head.
I have a Viair 400C compressor. Looking at the hardware to mount it with make me a bit nervous. It mounts via a grommet/brass bushing in 4 places. The i.d. of the grommet is approx. .20", which leads me to believe I will use 3/16" hardware.
hummm, a bit skimpy for a 5 lbs piece of equipment that's usually vibrating during run time.
so my questions are:
has anyone "hard" mounted their compressor (take the grommets out? if so, any failures due to vibration?
anyone had issues with the bolts being TOO small?
just trying to rectify something before I figure out my installation and wondering if I need to drill larger mounting holes.
thanks gang!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 02-16-2010, 09:01 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Compressor Mounting Question??
Doug,... I think Viair recommends them to be rubber mounted.
Are you sure a 1/4-20 bolt won't go thru the mounting holes?
I would just use nylon lock nuts with them.
(or maybe a 6mm bolt)
Old 02-16-2010, 09:21 PM   #3
tcb-1
tcb-1's Avatar
Keith,
The bushing .i.d is .197/.200, so I'm guessing 3/16" hardware is what Viair had in mind. As a matter of fact, the hardware they provided with the compressor is reeeeeeal low quality, black oxidized grade 2 (if even grade 2).
guess I'll just go with your recommendations with ny-lok nuts and keeping the rubber mounts........ and grade 8's (if available).
Doug
Old 02-16-2010, 09:41 PM   #4
lolife99
lolife99's Avatar
Looks like a #10-24 or #10-32 bolt.
Maybe something with an allen head or button head.
Old 02-16-2010, 10:11 PM   #5
tcb-1
tcb-1's Avatar
yep, think your right. looks like #10-24 UNC
why is it that I still think that's just too small?
oh well.... thanks for you thoughts, Keith
Doug
Old 02-16-2010, 10:13 PM   #6
jlaird
jlaird's Avatar
I agree. I think the mounting hardware sucks. I bought i believe 10-24 stainless bolts with allen head, lock washers and loctite. Nylocks would work too.
jlaird is offline   Reply With Quote
Old 02-16-2010, 10:49 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
I won't try to advise you about the mounting hardware since it's been covered. I will tell you that you do not want to solid mount it.
Mine is mounted on the rear most crossmember, and it still vibrates all the way to the front.
We tried tightening it down once.....BIG mistake.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-16-2010, 10:54 PM   #8
tcb-1
tcb-1's Avatar
looks like rubber mounting is the ticket then.
I appreciate everyone's input!
Doug
Old 02-16-2010, 11:02 PM   #9
MTCHEVY
MTCHEVY's Avatar
My bolt charts say that a #10-24 bolt (grade 2) has a proof load of 55ksi (55000 psi) and a 720 lb clamp load. It think 4 should have no problem holding a 5lb compressor? Look forward to see more pics!
-M.J.
1968 Stepside
MTCHEVY is offline   Reply With Quote
Old 02-17-2010, 08:26 AM   #10
dznucks
dznucks's Avatar
i thought the same thing about mine. i came across some titanium 3/16" fasteners. should hold.
I welded up my compressor bracket last weekend. i decided to mount mine in the far back corner, behind the passenger side tire. I have made rubber isolators for the bracket too. hopefully having two sets of vibration isolation will help.
dznucks is offline   Reply With Quote
Old 02-17-2010, 09:30 AM   #11
tcb-1
tcb-1's Avatar
55k psi tensile is per square in. #10 capscrews, at the major diameter, has .0265 square inches of material. so in fact the tensile strength is 1462 psi.
and these numbers are under a static load. the compressor, by nature, should be considered a dynamic loading (to be safe).
Doug
Old 02-17-2010, 09:02 PM   #12
MTCHEVY
MTCHEVY's Avatar
10/4
-M.J.
1968 Stepside
