Old 05-24-2002, 07:46 PM   #1
SoCal71K20
Post Trying to match sending unit/gage ohms
I knew I should have payed more attention
during the auto electrical theory part.
Anyways,I know that original temp. sending
unit has resistance listed as 72-88 ohms@
220 degrees.I will use original type gage
with one wire hookup.I cannot use 72-88 ohm
sending unit because of head swap and I want
to keep it off of intake manifold if possible.I can get a newer style sending
unit thats listed as 138-156 ohms @220
degrees.Is there any way to match resistance
to gage?Use of resistor?Hope I didn't word
this too confusing.Thanks.
SoCal71K20 is offline   Reply With Quote
Old 05-24-2002, 07:52 PM   #2
robby
Semper Fidelis
robby's Avatar
Post
I would like to know myself, I have a 307 with later model 305 heads and it has a smaller hole for the sender, I have it in the manifold but I don't like it.
72 C-20 parts 70 C-10 lwb driver
69 C-10 lwb parts
72 K-5 Blazer-NEW!
Lamar,Missouri
Semper Fidelis
72 Chevy C 20 with 402 For sale
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
robby is offline   Reply With Quote
Old 05-24-2002, 08:09 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I doubt it.
You are trying to make a high resistance part work on a low resistance syatem. If it were the other way around, it would be easy.
you could always remove the head and have the machine shop hog it out. But that soundsa a little extreem to me.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
E-mail longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-24-2002, 09:16 PM   #4
RodC
RodC's Avatar
Post
You could try to put a resistor in Parallel with the sending unit to bring it down to the proper range, provided that the upper range of the sending unit minus the lower range of the sending unit is the same on the low resistance sending unit as the high resistance one.
Remember resistors in parallel will reduce the resistance, resistors in series are additive. Thus two 4ohm resisters in parallel = 2ohms
The average of the low resistance sending unit you mentioned is 80 ohms. The average of the high one is 147. In theory, a 20 ohm resistor in parallel with the 147 will give you 83 ohms. (20+147) / 2 = 83.5 Your best bet would be to use a variable resistor to set it at 220 degrees. Then check the sending unit at various temperatures to see if you can obtain a correlating resistance between the gauge and the sending unit.
OR…….
Or you could just find an adapter that would allow you to put your sending unit into your head. I know a lot of after-market gauges come with various adapters?
Rod Childers
'71 C10 Stepside
Rod Childers
'71 C10 Stepside
RodC is offline   Reply With Quote
Old 05-25-2002, 02:35 AM   #5
Mudder
Mudder's Avatar
Question
then how can we get our newer sending units to work with or old gauges? (gas gauge)
67 stepside 4x4 Owensville MO mudder67@hotmail.com
[This message has been edited by Mudder67 (edited May 25, 2002).]
Mudder is offline   Reply With Quote
Old 05-25-2002, 09:23 PM   #6
RodC
RodC's Avatar
Post
What is the Restiance range of the old Sending units? (Full - Empty)
What is the Resistance range of the New Sending Unit? (Full - Empty)
Check both of these out with an OHM meter or the spec sheet and let me know.
Rod Childers
'71 C10 Stepside
Rod Childers
'71 C10 Stepside
Old 05-25-2002, 09:52 PM   #7
bigvinnie
bigvinnie's Avatar
Post
I'm running a tank from No Limit Engineering that came with a VDO sending unit that works fine with the stock fuel guage.... as I recall, the instructions for the sender said it was rated at 0-90 ohms... I just played with the length of the float rod to get it to read empty/full with the corresponding float level.
The VDO sender works great with the stock fuel guage...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
http://www.ixpres.com/vlusardi/chevtrk.htm
72 Stepside Project
bigvinnie is offline   Reply With Quote
