Old 01-31-2003, 02:41 PM   #1
bigblock73
yeller
bigblock73's Avatar
power/non power locks
Will the door locks on a manual lock door work on a door with power locks?
I bought 89 Blazer PW/PL doors but they did not come with any keys, I want to take the locks out of my NON power lock equipped doors and use them in the Blazer doors (since I have keys for them).
TIA - Jeff
bigblock73 is offline   Reply With Quote
Old 01-31-2003, 02:50 PM   #2
Zilverado
Zilverado's Avatar
I took the lock cylinders off my '77 non-power and put them in my '86 powered with no problem.
Neat story here:
The '77 was my father's (now deceased) truck, so it had some sentimental value to it. When the truck finally died (body rusted to nothing) I replaced it with the '86. The lock cylinders on the '86 did not operate properly. So now with the lock cylinder swap, I can still use my Dad's door keys on my new truck.
Anyway, sorry for getting all sentimental, but sometimes it's the little things that make something special.
So, bottom line - it should work for you.
Zilverado is offline   Reply With Quote
Old 01-31-2003, 02:51 PM   #3
PHOENIX
Jeff I would think so, but you might need the rod that leads up to the actual knob, I think power locks have a shorter rod.
I would like to know the opposite. Does power locks, work on a door with manual locks? I need to convert to power locks and want to know if I can use stock, lock actuators or do i need aftermarket?
EDIT:
I may not have understood your qeustion correctly , so you can excuse the first paragraph.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 01-31-2003, 03:44 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I am assuming you are talking about the lock cylinder mounted in the door. If that is the case, they are all the same.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
