Old 02-16-2010, 10:00 PM   #1
Envy
Envy's Avatar
Air Management Mounting ?
How is everyone mounting their compressors, valves, tank, lines, ect. Im doing full air ride and want the cleanest setup possible. I plan on using a valve block type setup, but havnt decided on one or two compressors, and one or two tanks. It will all be hidden underneath, i dont want anything mounted in the bed. So i need some ideas to make it as clean and functional as possible.
Pictures? Suggestions? Ideas?
Envy is offline   Reply With Quote
Old 02-16-2010, 10:54 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Air Management Mounting ?
Take a look here-
LINK
LINK 2
LINK 3
LINK 4
Those should keep you busy for a while...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-16-2010, 10:55 PM   #3
Envy
Envy's Avatar
man, i must suck at searching, thanks for the help great ideas in these links.
Old 02-16-2010, 11:03 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
No prob. FYI I used "tank mounting" as search criteria. I knew that topic had been covered more than Air Management.
Feel free to discuss your plans and post pics when you can.
Articles-
"Refining Sierra"
Old 02-16-2010, 11:07 PM   #5
Envy
Envy's Avatar
What are they using for hard line, i did do a search for that, and found arguments on copper, hydraulic line, ect. I also see where people say you cant go wrong with DOT, but the hard line is so dang clean looking.
Old 02-17-2010, 01:01 AM   #6
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I used 3/8 stainless with JIC fittings. It was NOT cheap.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-17-2010, 02:20 AM   #7
miracle whip
miracle whip's Avatar
I would use dot line, the stuff last forever and is quick easy and cheap you can go with black and it will blend in with your frame or colored so it will match other stuff. I used angle iron for mounting everything, its strong so your tanks are secure and its cheap. you want to mount your pumps to somthing solid "not sheet metal" so you minimise vibration and definitely use the rubber mounts that come with the pumps. if your like me and use your air ride like its a video game then you want two pumps and more air compacity, If you want to lift it up to ride height and leave it, then go with one!
miracle whip is offline   Reply With Quote
Old 02-17-2010, 10:21 AM   #8
crakarjax
crakarjax's Avatar
Good tips, I was wondering why one would go for two instead of one.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
