What is this on the firewall?
Re: What is this on the firewall?
I screwed up and posted this on accident without putting in my real question first. I actually want to know what the metal serrated tab is that is bolted to my firewall on the left of my fuel pump relay. I've seen the same metal tab on other trucks, but nothing is attached to it and I can't find reference to it in any manual. It looks stock, so I'm assuming the factory put it there. Any advice is appreciated. Thanks!
Looks like a grounding point of some sort.
6.0 powered square
looks like a relay what year is the truck
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
Wow 3 posts at 10:16!! I had posted the same answer and edited it after I read his updated question.
The truck is a 87'. If you see my post below my original after I hit enter on my original one by accident, you will see what the real question is. Thanks
6.0 powered square
your second post didn't show up until I posted
I had one on my truck in a different spot. That thing was sharp so I just took it off.
1977 GMC Sierra Grande |
I have car A.D.D.
Could it have been for a second relay to clip on to? Where is Keith when we need him?
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. Last edited by Driveway Dreams; 02-17-2010 at 01:21 AM. |
its actually a wire loom securing bracket there used to be a plastic ring clamp that would clamp around the loom and then it had a slot that the metal tab slid into the serated edge acted as a grip to hold it like a piece of wood grips a nail.
#12 | ||
![]() Quote:
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-17-2010 at 08:45 AM. |
#13 |
One shot, one kill.
OH, OH, OH, Mr. Cotter I know what it is. That serated tab is supposed to ground the hood to help RFI interference from the ign reaching the radio antenna in the windshield. I took mine off because it scraped the paint on the underside of the hood support framing. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
#14 | |
Yep - that's what I meant by "grounding strap". K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#15 | |
Junior Member
We have a winner ![]() |
#16 |
Just a followup - my '87 does not have that on the firewall.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-17-2010 at 08:22 PM. |
#17 |
Thanks for all the replies. I would assume that when the hood is closed the metal tab touches the hood, thus grounding it? And it would be serrated to better connect to the hood? Maybe I'm missing something but I would have thought a true strap with enough slack to open the hood that was bolted to the firewall and connected to the hood would have provided a better ground. I know it's a trivial thing, just interesting some trucks have it and others don't in the same year and it's such a strange design for function.
#18 | |
I really hate wet sanding!
![]() Join Date: Dec 2008
Jeff, 68 C-10 75 C-20, now a C-10! 10 F-150 |
#19 |
if you are talking about the tab next to the relay its where you attach another relay
#20 | |
K
#21 | |
Yes on both counts. I have seen vehicles with an actual braided strap (my Chevelle was done that way) - which is probably more effective - but this serrated tab is probably cheaper from a piece cost and labor standpoint. K
