Hey all,
My son has a 1972 K20 pickup with power steering, 6" lift, and a later model 12 bolt front axle. The truck turns to the left fine but hardly turns to the right. I can't see any big problem in the steering linkage, and it looks like the pitman arm only fits on the steering box one way. This is a real pain (and safety issue) when we drive it. Any ideas what we should look for? Thanks! Colby. |
Active Member
![]() Join Date: Jul 2007
Re: Doesn't turn!
First thing is to jack the front end and place it on stands. Test the steering this way to see if it acts the same way or if there is any difference in the effort to turn to the right.
This is just to eliminate any possibility you may have missed something in the linkage. But, from your description, I'd guess the gearbox has a problem. If it was the pump it would fail in both directions. It's something I wouldn't take a chance with and I'd start looking for a replacement. I had one on another vehicle that would lock up every now and then. Now that's scary... And they're not the easiest part to tackle if you're not familiar with them. |
The Few, The Proud
![]() Join Date: Jun 2007
Re: Doesn't turn!
Did you/he install a drop pitman arm to compensate for the 6" lift?
Shannon Last edited by sdailey; 02-17-2010 at 01:08 PM. |
Re: Doesn't turn!
Make sure you count the turns left to right so you get the pitman arm centered.
Re: Doesn't turn!
Agreed!! He most likely did not and that is where he is looking his steering. The linkage going from the pitman arm to the axle should be level. If its at an extreme angle you will loose your steering one way as well as you will bet alot of bump steer. You may also want to look into crossover steering. Not sure what front end he has but I dont think GM made a 12 bolt front end. Most likely a 10blt or a dana 44. Both of whick i think they make crossover kits for. sterring will me 100x better after the conversion also. Good luck and keep us posted.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
#6 | ||
Re: Doesn't turn!
Turning to the left and not to the right is almost certainly from not addressing the steering linkage when the lift was installed. For 6" of lift a raised steering arm is an absolute minimum, and adding an off-set drag link will make centering the steering wheel easier too. This will get your turning radius back to where it should be. Pictures?
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() Last edited by LONGHAIR; 02-17-2010 at 08:32 PM. |
Active Member
Re: Doesn't turn!
Okay, I reread the original post and I have to admit I misread "The truck turns to the left fine but hardly turns to the right." My dislexic brain wasn't completely awake and I read it as "hard to turn to the right."
![]() So, I take back the gearbox suggestion but the jacking up the front to analyze the situation is still a good idea. You can see where the limitation is and what you may need to do to correct it... |
![]() Join Date: Nov 2007
Re: Doesn't turn!
Did it ever turn right? I had a longhorn that would only turn to the left easy, the right was hard to turn. I pulled the old powersteering fluid old and replaced it with Lucas Powersteering treatment, after about 15 minutes it was steering good, never anymore problems.
Re: Doesn't turn!
Wow thanks everybody! First, the truck already had the lift on it when we bought it ( one of the attractions to the truck for my 18 yr old kid ) and I was suspicious of the angle of the drag link. It does not appear to have a dropped pitman or raised steering arm ( when compared to my stock '72 K20 ). Second, I did mean a 10 bolt front axle, not 12. The steering has not changed since we have owned it. I tried pulling the pitman arm and centering the steering shaft but the shaft and pitman only fit together in one position. Anyone have a source for an inexpensive dropped pitman arm and offset draglink?
Thanks for all your help, Colby. ![]() Last edited by Farmstore34; 02-18-2010 at 12:42 AM. |
Re: Doesn't turn!
Their are a couple venders on the board that im sure will chime in but in the meantime the only place I can think of that carries them would be like 4-wheel parts if you have one close to you.
