01-31-2003, 04:18 PM | #1 |
model code ?
good day.
I just picked up a '67 chev lwb 3/4 t. It came with a stepside box but of the wrong year ('60-'66?). I want to find out what the truck is supposed to have but the model code on the inside of the glove box door has been painted over is there another spot that has this info or some way of finding this out?? thanks, eh! |
01-31-2003, 04:38 PM | #2 |
Mike
Should be in the VIN # should have 2 letters and then the first # is the gvr and the next# is the bed. if it's a 4 it's a stepside
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
01-31-2003, 04:55 PM | #3 |
thanks guy i'll check it out
but if any body knows how to find out what was on the g.b.d. I would sure like to know.
'67 Chev lwb soon to be daily driver '68 Mustang 390 gt/California Special full(very slow)restoration '77 T-Bird retired due to 400cid Last edited by jer; 01-31-2003 at 05:04 PM. |
01-31-2003, 05:54 PM | #4 |
He's got mean nasty FANGS!
All the VIN will tell you is if it was a Chassis/Cab (no bed, or flatbed) or a Cab and Bed combo, 4 means Cab and Bed, 3 means Chassis Cab. I'm not 100% sure on this, but I believe if you contact GM of canada (assuming it was built in canada) you can get a copy of the original options when you request a restoration pack, only downside is it costs $50 I think.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
01-31-2003, 05:57 PM | #5 |
For more info on VINs and model codes go to: http://67-72chevytrucks.com/Chevyear.html
01-31-2003, 08:19 PM | #6 |
depending on what shape mine still had the model no on the rear frame cross support facing the back just a shot
72 Chevy K10 Short Stepside 72 gmc K2500 |
02-01-2003, 01:10 AM | #7 |
its all about the +6 inches
The bed you have should be the same box, all you need is the proper fenders to bolt on.
02-01-2003, 01:24 AM | #8 |
You might check inside the seat or behind the gas tank for a build sheet. Other folkes have found them but not me.
Do a search on the site for build sheets there should be some good information in the archives. The glove box data sheet on my trucks had plastic covering them If the data sheet is still attached there may be some way of removing the paint and still be able to read it. Just a thought
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
02-01-2003, 03:20 AM | #9 |
a wealth of information!
'67 Chev lwb soon to be daily driver '68 Mustang 390 gt/California Special full(very slow)restoration '77 T-Bird retired due to 400cid |
