02-17-2010, 02:44 PM | #1 |
Coil springs
Hello,
The 67-72 chevy trucks can use the 73-87 front coil springs, right? |
02-17-2010, 09:03 PM | #2 |
Re: Coil springs
yes
02-17-2010, 09:49 PM | #3 |
Grandpa in the rustmobile...
Re: Coil springs
whatta bout drop spindles? I have 71 chevy 1/2 frontend setup, can I use say..78 1/2 ton 2x4 drop spindles?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
02-17-2010, 09:59 PM | #4 | |
67-72 parts collector,…
Re: Coil springs
With the correct ball joints and outer tie rod ends.
02-17-2010, 10:44 PM | #5 |
Re: Coil springs
Ok, so there not the same balljoints tierod ends as 71 72? Darn lol
02-17-2010, 11:05 PM | #6 | |
Re: Coil springs
71-87 lower ball joints are all the same. So,... you could get away with changing just the upper ball joints and outer tie rods.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-17-2010 at 11:06 PM. |
