Shake and Bake!
![]() Join Date: Feb 2010
Extra pulley on crank and water pump?
Hey guys,
I have a 72 C10 with a 350, my crank pulley has a wobble and I need to replace it. The balancer is newer and spot on. But I have an extra pulley bolted to the front of my crank and water pump? There is some type of mismatch going on here from the PO, what do you guys think I should do? Take a look at the pic, and let me know. Thanks! ![]() ![]()
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
Re: Extra pulley on crank and water pump?
does it have a long or short water pump? almost looks like it needs a short if not... and maybe they added the power steering later?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Shake and Bake!
Not sure, how do you differentiate between the two?
did they have air pumps in cali in 72?
Just Not Low Enough!
thats defiantly a long pump. see the gap between the timing cover and the back of the pump. on my motor the alt/water belt runs behind the p/s pulley.
i agree, it looks like it needs a short style pump.
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd ![]() Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
Shake and Bake!
I think maybe I have the long pump, and the alternator (passenger side) bolts to the water pump housing. and the power steering pump must be for a later model to line up with these pulleys.
But I am still confused, please take a look at the pic and let me know what you think I should do. I was planning on replacing the PS pump anyways cause its oldand ugly and is starting to make a little noise. I don't mind putting a short water pump in it, they are cheap. But how do I get the alternator to line up? New brackets I guess, but did the alt come on the drivers side stock. If someone could give me some guidance on what parts to replace to get me back to stock I would be stoked.
maybe a few more pics from both sides will help...
Shake and Bake!
Posted a different thread with better info and pics here:
http://67-72chevytrucks.com/vboard/s...d.php?t=387357 Sorry for the double post.
never finish start another
Looks like a short water pump my fix the problem. I am looking at my short pump now. It will move the puleys back.
Watch out for your cornhole !
![]() Join Date: Jun 2003
That's a long pump.
To convert to short you will need the pump, alternator brackets, water pump pulley and belts. The alternator is on the driver's side when running short water pump setup.
Shake and Bake!
Problem solved, got a new OE GM complete serp setup for next to nothin on craigslist. Thanks for the replies guys! I was a lil stressed for a minute lol.
I think the pump on the serp system runs in the opposite rotation to the older belt drives water pumps
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! Last edited by Willys47; 02-18-2010 at 12:30 AM. |
#13 | |
Shake and Bake!
Thanks man.
#14 |
Sounds like a good time to install an electric fan.
