Old 02-17-2010, 06:40 PM   #1
Black66step
bbc swap
Hello all,
New to board but have read a good few threads. Putting BBC in 64. Already had SB. What is the ECE mount one person referred to? Said he would have gone with it over the POL version for more header clearance. Thinking of using BBC towers with the cheaper SB rubber mounts. Going with a T56 tranny. Thanks
Brian
Black66step is offline   Reply With Quote
Old 02-18-2010, 01:44 AM   #2
Captainfab
60-66 Nut
Re: bbc swap
Welcome to the forums
You can also use the '73-'87 mounts for your big block install. Take a look in the 'Projects and Builds' section at protrash64's 1964 Suburban pics thread. Those are what he's using for his BB install. I prefer to use the '73-'87 motor mounts when possible. They are better mounts IMO.
Old 02-18-2010, 06:21 PM   #3
Black66step
Re: bbc swap
Appreciate the info. Was just curious as to who is getting the most exhaust clearance, the late model mounts or the tubular style by POL and such.
Anybody else done the 6 speed?
Old 02-18-2010, 06:52 PM   #4
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: bbc swap
Brian
I was going to do the BBC swap with factory mounts, but they were to low and the oil pan hit the crossmember. I have not seen the ECE stands, I search on their site but they do not show them...
Were in Longview are you? I live in Spring Hill area.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-18-2010, 11:59 PM   #5
Black66step
Re: bbc swap
Yea Karl I noticed a big block (core) in your first pics of your truck. Noticed the perches were in the front holes. You say it sat too low huh? I'm gonna try to pick up some late model mounts and play with it some. Like you I'm anxious to get mine going again. I've got a couple BBC's, running them in my jetboat. I've got a nice late model ( 1 piece rear main)4bolt main .030 over SB with the complete serpentine set up, distributor, wires, everything, if you know someone in our area looking. I was gonna put this motor in the truck with the 6 speed, but now It's Big Block or No Block
By the way, you work near Longview Airport? I know theres a coil manufacturer over near me.
Old 02-19-2010, 11:40 AM   #6
aggie91
aggie91's Avatar
Re: bbc swap
I actually work over on Gum Springs Road, between Eastman Road and Cotton, at AAON Coil Products.
I am going to post some pics of the mounts I have in this section some time today. Yes, I did have mine in the front location and it sat to low, but I may not have had the correct mounts that bolt to the block...
Karl
The LST Challenge:
Old 02-19-2010, 11:43 AM   #7
Chevy Fleetside
Chevy Fleetside's Avatar
Re: bbc swap
Here is the clearance with the tube type engine mounts. The Headers are Hedman Elites.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-19-2010, 11:51 AM   #8
aggie91
aggie91's Avatar
Re: bbc swap
Chevy Fleetside - Who is the manufacture of those mounts? part number?
Karl
The LST Challenge:
Old 02-19-2010, 12:20 PM   #9
Chevy Fleetside
Re: bbc swap
http://www.truckandcarshop.com/trucks60_72/t60_097.html Bottom of the page in the middle.
Old 02-19-2010, 02:15 PM   #10
Black66step
Re: bbc swap
Chevy Fleetside- was it you that said you went with tube type
but would use the ECE type if done over again? I didnt see anything but ls type mounts on their site.
Are you happy with yours? Notice theyre in the back holes also?
Brian
64 step BB/ T56 makeover
Old 02-19-2010, 02:19 PM   #11
Black66step
Re: bbc swap
Fleetside- appreciate the pics
do you like the way headers exit?
Brian
Old 02-19-2010, 05:56 PM   #12
Black66step
Re: bbc swap
Hey Karl give me a shout 903 352 0219
Brian
Old 02-19-2010, 06:07 PM   #13
Chevy Fleetside
Re: bbc swap
That wasn't me. I have not gotten the truck running yet. I had to knoch the firewall to get the heads/valve covers to clear. I do have a build thread and some pictures of what I did.
http://67-72chevytrucks.com/vboard/s...d.php?t=259536 You can see pictures here and the very last picture is the way it is now.
Old 02-19-2010, 06:27 PM   #14
Black66step
Re: bbc swap
Fleetside--what year truck did you nab everything for the serpentine? I've got some stuff
Brian
Old 02-19-2010, 08:44 PM   #15
Chevy Fleetside
Re: bbc swap
I bought that new from summit. It is for 88 and up. http://www.summitracing.com/parts/NAL-19172805/ Of course I didn't pay that much for it at that time. I figured if I got a used unit with over 100,000 miles on it, I would be replacing stuff anyway. So I went new.
Old 02-20-2010, 12:20 AM   #16
Black66step
Re: bbc swap
Im with you fleetside! Im goin that route! I should be able to get that kit a little cheaper through gm.
Appreciate all the info!!!!!!
Brian
Old 02-20-2010, 03:47 PM   #17
structures
structures's Avatar
Re: bbc swap
That was Clyde... check out http://67-72chevytrucks.com/vboard/s...d.php?t=386295
Originally Posted by Clyde65 View Post
I used the perches from POL ( Performance on Line), if I were to do it again, probably would use the ECE mount, just because of better Exhaust clearance. The trans mount you can get just about anywhere, the simpler the better on trans mount.
I'm using the ECE mounts in a 65 chevy with a 2006 5.3l. I've set the engine in so far and from what I can tell the exhaust manifold flanges are hitting the frame a little on the drivers side. I'm hoping to just clearance the frame a bit.
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 02-20-2010, 05:38 PM   #18
mike16
Re: bbc swap
I put a 454/th400 in my 63. knowing now what I did not then I would have done it a bit different, especially around the fire wall, when its stated there is little clearance that is an understatement, What I would do is get a portion of a 67 and latter fire wall and graft it in place of the 66 and older. Done correctly you can retain the brakes and delux heater.
mike16 is offline   Reply With Quote
Old 02-24-2010, 12:54 AM   #19
64bigblock
Re: bbc swap
wered ya get the motor mounts
64bigblock is offline   Reply With Quote
Old 02-24-2010, 11:37 AM   #20
Chevy Fleetside
Re: bbc swap
Who is he asking this ? to?
