Old 02-17-2010, 07:37 PM   #1
tvillebowtie
How many cross braces?
How many cross braces on a new wood floor? This project started out as a steel floor,so I have no idea how may braces I need to get.Thanks
tvillebowtie is offline   Reply With Quote
Old 02-17-2010, 09:55 PM   #2
seafoam68
seafoam68's Avatar
Re: How many cross braces?
It depends on long bed or short. Long bed has one more than short. This drawing shows long bed. (Courtesy of LMC Truck.com)
seafoam68 is offline   Reply With Quote
Old 02-17-2010, 10:19 PM   #3
SBC
SBC's Avatar
i just completed a woodbed conversion on my 67 shortbed. i think this is what it should look like assuming i put it together right.
1967 C-10 Project
2008 Suburban
2017 GMC Sierra
SBC is offline   Reply With Quote
Old 02-17-2010, 10:23 PM   #4
AusTx68
AusTx68's Avatar
Wow, excellent photo SBC! I'm in the middle of the conversion for my 68'. I use the same supporting boards but did not use the smaller boards for the reinforcement supports. After seeing this I plan to set it up the same way. Thanks!
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 02-17-2010, 10:29 PM   #5
SBC
SBC's Avatar
thanks, your earlier photos actually helped me a lot. i put this thing together myself which was pretty touch but got it done. i would have run boards all the way across instead of the small ones but was short on wood.
the boards you see i cut from the wood frame sent with the new headboard sent by Mar-k. hahaha
1967 C-10 Project
2008 Suburban
2017 GMC Sierra
Old 02-18-2010, 12:44 AM   #6
Willys47
Willys47's Avatar
I have a pics here I hope it helps
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 02-18-2010, 12:47 AM   #7
tvillebowtie
Thanks Willys,great pictures.I am curious about the one brace looks different than the other ones.It's the one in front of the wheel tubs.Thanks for the help everybody.Z
Old 02-18-2010, 01:01 AM   #8
Willys47
Willys47's Avatar
The frame rises up at this point and the brace needs to be shorter to keep the wood flat and support the wheel tubs
