Old 02-18-2010, 12:05 AM   #1
sider68
sider68's Avatar
Budget Brake Delemna
Hi and help
i have a 6 bolt drum brake set up.Should I just add power all the way around OR should I put disc on front?
If I go disc then I will have to change to 5 bolt all the way around?????
I still have to add power steering cant afford to go too far over budget but I would like to get it all done by spring
sider68 is offline   Reply With Quote
Old 02-18-2010, 12:07 AM   #2
dan76
Re: Budget Brake Delemna
I just read the stickies on disc brake conversions. It's located at the beginning of this forum. Answered all my questions.
Here's the link: http://67-72chevytrucks.com/vboard/s...ght=disc+brake
dan76 is offline   Reply With Quote
Old 02-18-2010, 12:09 AM   #3
BIGBLU 72
BIGBLU 72's Avatar
IMO i would add power to them! ive never had any problem outta my drums and pull stuff all the time with mine
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 02-18-2010, 08:42 AM   #4
rsavage
rsavage's Avatar
You could start by adding power and by making sure all your shoes, wheel cylinders, lines and hoses are good. When you are ready financially, you can do the disc conversion, which will be significantly more costly, especially if you have to change wheels. You will still be able to use your booster set up but will have to get a proportioning valve to replace the distribution block used on the drum/drum set up. Non power drum brakes are terrible. Power drums, if all the components are in good shape, work pretty well.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-18-2010, 09:46 AM   #5
68gmsee
Active Member
68gmsee's Avatar
6 bolt discs are available if you don't want to change wheels. Steep though.
From Classic Heartbeat: http://www.classicheartbeat.com/67-7...suspension.htm
68gmsee is offline   Reply With Quote
Old 02-18-2010, 10:04 AM   #6
cdowns
cdowns's Avatar
drums are good if you know how to read a service manual and maintain them
Old 02-18-2010, 10:04 AM   #7
Sinister
Between Trucks...
Sinister's Avatar
CPP has 6 lug rotors for $129.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-18-2010, 10:12 AM   #8
sider68
sider68's Avatar
It looks like i will just add power to existing drums. Are all parts available through jobber or Napa etc .(just wondering because of age) I have a resto truck place close but prices are high
