Old 01-31-2003, 06:24 PM   #1
teeitup
Just like to part out trucks!!
teeitup's Avatar
front axle ???
My left front axle is broke at the u-joint in my 72. Its a dana 44 frontend. One guy told me they came out with smaller axles in early 72 and bigger axles in later 72. What years will work on this thing and does it hurt to put a bigger axle for bigger ujoint in that side? Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 01-31-2003, 10:11 PM   #2
ljbear
ljbear's Avatar
I'm not sure about years and axle sizes, but if the overall length and spline count is correct it will be fine. I mixed shafts on a jeep without any problems. I initially broke the right side and replaced it with a larger diameter shaft. I bought both Left and Right to replace, but only did the right one right away. I carried the left side that matched the larger one as a spare, and then finally swapped it out after about a year. If you can get a match that's probably the best way to go.
Larry
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 02-01-2003, 02:17 AM   #3
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Randy, the 73 to 77 dana 44 used the 297 u joint which is about 30 percent stronger than the 260x that was used till 72, try and find a set of axle shafts from a 73 to77 after that chevy used the 10 bolt front, or 73 to 81 on most GMC trucks, just watch the 73 axles because some of the early models had the small axles. It doesnt matter whether its a 1/2 or 3/4 ton axle because the shafts are the same, this is definetly a good upgrade to do and you could do just one side for now but it if it were me I would go ahead and do both sides. If you do this yourself email me and I will tell you how to make a tool to clean out your axle tubes, you should allways do this before installing an axle so you dont push a bunch of dirt and scale right into your diff. It would also be a good time to replace your inner axle seals and hub seals.
BLAZERMAN is offline   Reply With Quote
Old 02-01-2003, 10:17 AM   #4
teeitup
teeitup's Avatar
THANKS for teh info guys, I appreciate it!!!! Rob, my mechanic is going to do it. I'd probably screw it all up. Thanks again Randy
1980 chevy swb 4x4
Old 02-01-2003, 11:07 AM   #5
6869704X4
Im doing xover steering and gear work so I happend to have mine out. It doesn't take a rocket sceintist to figure out which one is stronger. 73 and up on the left. Axle out of my 70 on the right.
Guess which one I'm gonna use?
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 02-02-2003, 10:12 AM   #6
teeitup
teeitup's Avatar
I found one for a 72 for a $100 is this to much? Randy
1980 chevy swb 4x4
Old 02-02-2003, 11:09 AM   #7
6869704X4
Is it the beefy one? Im not sure what theyre worth. I got a whole D44 for $100 but that was pulling it myself.
Old 02-02-2003, 11:38 AM   #8
BLAZERMAN
BLAZERMAN's Avatar
Randy, if he wants that much for the complete 44 then thats not to bad, if its a 72 it will have the small axles but since your only running 33" tires you could just use the axles out of it after putting in some new u joints and you should be fine. If it were me I think I would keep looking for a set of the later model axles, you should be able to find a set of shafts for about the same money. If you want I can go by Pettyjohns and see what he gets for a pair.
Old 02-02-2003, 11:59 AM   #9
teeitup
teeitup's Avatar
Thats just for the left side axle, I thought it was high for just a axle. I have the axle out of the burb I parted I might just pull it and then try to find another for it. Thanks Guys Randy
1980 chevy swb 4x4
