![]() Join Date: Jan 2007
Date of manufacture
Is there some way to determine this from the numbers on the blazer or the frame? Some of the grease pencil marks? I was trying to find this date so as to reproduce the blue sticker on the driver door correctly as mine was deteriorated at that area of the sticker so I was unable to read it. I have the VIN and such, several grease pencil numbers on the frame and the body which I have good documentation of. Any help appreciated!
SKINNY TIRES RULE!
Re: Date of manufacture
Mine has a date in grease pencil on the top of driver's side inner fender.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Did not have that but did decode the engine to July 10, 1970 so I think it was a date of July 1970, which I remember that date for some reason, maybe a mental note from the blue tag. I took lots of pics but never seems to be the exact one I need!
Yes there were on mine, on frame under driver and frame in engine compatment passenger side. Mine were both there and I documented these as correct.
Here is another big question... What was the total manufacture numbers or VINs issued by Chevy for the production run year of 1970? Reason being, my VIN numbers corresponding to the number it comes off of the line (the way I understand it anyway) is 86943. It was manufactured sometime July 1970 based on the engine codes so that would make it a fairly late run as the new model year is getting ready say August - September time frame. Any ideas on that? Doesn't make a hill of beans difference but just fun checking out this stuff. I did count the numbers of trucks and related and came up wit a total of 43827 but there are lots more others than that.
#7 | |
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
#8 | |
Sort of - The sequential number would pretty much represent the vehicles produced on that assembly line only (in other words, it would not comprehend vehicles produced at other assembly plants - which would get their own set of VIN sequence numbers). Also - there can be some trickery where the sequence number could start at a different point based on either (a) engine option or (b) nameplate. In your case you are probably ok with a Chevy, but for example during the '73-87 era GMC badged trucks started at 500001. You are correct. A July 1970 build is a late (in the 1970 model year) build. By August we would be building a few very very early '71 cars/trucks, but the normal startup would occur in September. Additionally, the engine has to be built and completed prior to the vehicle build (plus shipping time) so that would push your vehicle build some time later in July or into August of 1970 - a pretty late build. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-18-2010 at 04:54 PM. |
Thanks for the informative responce. Since the blazer I have was produced in St. Louis, would there be a place to check on the number of 1970 vehicles that place put out?
I am not redoing the blue decals from ebay, those look just fine to me. I ordered one and should be here soon.
#12 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#13 |
I got the one from e-bay yesterday and it is a beautiful reproduction, accurate and even comes with the clear cover seal to apply over the decal when it is put on. Oddly enough, it came from the Inline Tube company or at least it was packaged by their stuff. Now to just find a person that could do the typeing for me on period correct typewriter! Since we all use word processors now, may be a challenge.
#14 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Don, the factory didn't use typewriters to type out these or Spid's. The fonts will be different. They used big machines that layed out the words real quick and kept moving. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#15 |
How do we reproduce the type on these items?
#16 |
Here is a pic of mine before the redo!
#17 |
SWB 4x4 Collector
You need to contact Jeff (Chipflyer) as he is the only one I have ever seen duplicate the factory lettering on the spid decal. He might be able to duplicate these too. It's worth a shot. Trevor
#18 |
#19 | ||
The book I was referencing was John Gunnell's "Standard Catalog of Pontiacs - 1926 through 1995" which lists all the assembly plants, model year start up and end dates, as well as production volumes for each plant. I see they also have a "Standard Catalog of American Light Duty Trucks, 1896 - 1986" which I presume would have the same type of information. I'd start there if I were you - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-24-2010 at 08:09 AM. |
#20 | |
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#21 |
![]() Join Date: Feb 2002
I read sometime ago on this forum that the SPIDs were typed on an IBM Selectric electric typewriter. Or was it that SPIDs were best duplicated on that kind of typewriter -- being closest to the kind of industrial machine GM was using at the time?
